I hurt my transmission :(
Old Aug 28, 2002 | 09:00 PM
AwwsChwA's Avatar
AwwsChwA
Default I hurt my transmission :(
Me bein the genius that I am, I wasn't paying attention to what I was doing, and I threw my car into 1st gear, intending to shift into 3rd, going about 45mph The engine shot way past the redline, probably in the 9,000 range. It was only there for a second, at the very most, so the engine doesn't seem any worse off, but...
In 4th and 5th gear, I hear a very distinct whirring sound. I'm pretty sure that it's the outer shaft bearings (furthest away from the flywheel), since I don't hear it until I shift into 4th gear. It gets a little louder when it's in 5th. The transmission's always been noisy, it's high miles, nothing serious, just some very light static-sounding noise at low engine rpm.
Anyone know specifically which bearings I damaged? This transmission also has a failing 3rd gear synchro, so I was thinking one of two things...either just find a decent replacement, or tear it apart and invest in a Honda rebuild kit for the tranny. Any ideas? thanks
Old Aug 28, 2002 | 11:04 PM
IrradiatedKitty's Avatar
IrradiatedKitty
aww... poor baby i wish your car was happy... that's ok, i'll help you make it happy again if you need me too
Old Aug 29, 2002 | 04:42 AM
1stGenCRXer's Avatar
1stGenCRXer
GWAKS- Tech Geekifier
Honda doesn't sell rebuild kits for trannies, you basically have to go through the tranny and order each seal, bearing and synchro that you want to replace, clean everything, lube it initially and then re-assemble.
-Harry
AIM: NDcissive
Old Aug 30, 2002 | 07:23 AM
chanluder's Avatar
chanluder
thats a lot of work
Old Aug 30, 2002 | 07:48 AM
1stGenCRXer
Originally posted by chanluder
thats a lot of work
About 6 hours from time of disassembly to re-assembly as long as you don't have to re-shim any wear items, if you have all the parts on hand.
Austin Bees
Accord
6
Aug 31, 2005 07:51 PM
Snoopy
92+ Civic/EL & Del Sol
22
Oct 28, 2002 09:35 AM
j-speed racer
4
Oct 16, 2002 02:57 PM
Fly Si
Engine Swaps, Tech & Tuning
3
Oct 1, 2002 09:38 PM
yogi799
7
Jul 30, 2002 04:02 AM
