noob
Old Apr 19, 2005 | 03:39 AM
black4string's Avatar
black4string
so my civic harness will do fine? everything will bolt right up?
im just gonna have to wire for vtec? what else do i need to wire up?
thanks...
Old Apr 19, 2005 | 06:20 AM
gsr wannabe's Avatar
gsr wannabe
looks like we're sking the same thing, just diff engines
Old Apr 19, 2005 | 10:14 AM
bambbrose's Avatar
bambbrose
yes use your stock harness. ADD vtec signal and ground wires, knock sensor wire, and if you have a vx you have to do some o2 sensor modifications. if you don't have a vx, you just have to extend the o2 sensor wires.
here is a pic of my dx harness when I was redoing it for vtec. You don't have to tear your harness apart like I did, but I wanted it clean and I wanted all the wires inside of the looms.
Green is where you add the knock sensor wire and plug, just take it off your JDM harness.
Red is where you add the vtec wires.
run them up to the end plug, and then from your end plug you can run them down to your ECU. It's really not very hard at all
Old Apr 19, 2005 | 04:10 PM
black4string
thanks man, much needed answer...
Old Apr 19, 2005 | 05:51 PM
gsr wannabe
No shiite, I would've spent days looking over electrical schematics--
Don't critisize my spelling until you have the 5am to noon shift-- :sleep:
