what ratio would you recomend turbo b16a1
Originally Posted by b16ahybrid
What are the specs of the turbo?
9.6:1 gets my vote esp if your running a t3t4 and looking to make some decent power.
T3/T4 Hybrid
T04e Stage III Wheel
.50 a/r
.63 Exhaust
Originally Posted by olly-civic
its:
T3/T4 Hybrid
.50 a/r
.63 Exhaust
T3/T4 Hybrid
.50 a/r
.63 Exhaust
Here's my .02 cents.
I wouldn't recomend lowering your compression that much. I have a turbo thats close to the one your using but mines a .57 trim w/.63 a/r.
If your looking to make 300whp it's going to take about 13psi with an agressive tune. Thats with stock compression. I'm making about 280whp with a mild tune, stock compression, and 13psi.
That turbo will compliment your set-up nicely, but I would honestly keep the compression higher then 8.5:1.
Still here... sorta...
I say go 9.5. No way go 8.5:1.
Those injectors are not very well priced. Check it out: http://www.wiredspeed.com/itemdesc.a...%2D550&eq=&Tp=
compression has nothing to do with spool up guys it is all gearing. the flow of other parts other than the turbo will be what makes power it isn't all boost.
300BHP you should need no more than a bar of boost ona good tune.
It's going to take him more boost to make the same amount of hp. running 8.5:1 compression with an agressive tune will require about 16psi of boost. Now if he were to bump the compression to 9.5:1 or even 10.0:1 with the same tune it's going to take about 12-13psi of boost. Why do I even mention that, well without looking at that specific turbo's flow chart, I believe that turbo's peak isnt that high. Once you cross the turbo's peak it's your going to start to introduce more and more heat into the boost charge.
So whats better running more boost with higher heat or running lower boost with less heat and making the same power.
Like I said before, i'm running a simular turbo, inorder to reach my goal of about 400whp it's going to take a higher static compression to keep the turbo close to it's peak efficiency. And yes compression does effect the final outcome. Nobody is mentioning spool-up, not sure why your stuck on that.
i carnt do a 10:1 it wouldnt be right in the back of my head!!!
im getting the pistons on friday iv gone for the 9.5:1, iv also been offered a aquamist water/methanol injection kit, the pupme gas over here has a 98 octane rating, am i correct in saying that with the water/methanol mix being injected the octane would be higher or am i on the rong track???
also any thoughts on that intake manifold i found??? is it worth it?
Don't run more octane then you need, running 98 octane isn't going to be required for your set-up. If your only looking for about 300hp then 92 octane will be more then enough.
I agree. In CO we have 91 and that's all I run. I've never put race gas in it...
The injection system would be cool, but overkill for what you want to do. I'm interested in an injection kit, but I really need to know more about it before I commit.
