anyone know where to have rods shotpeened
Old Jan 12, 2005 | 07:06 AM
ISP James's Avatar
ISP James
DAMIMRED
Originally Posted by j87w
I hate to say this, but I cant really afford aftermarket right now.
If I were to go with aftermarket rods then I would have to go with aftermarket pistons also.
follow Mr. Rogers' advice: take your time and do it right
:bs: aftermarket rods /=/ aftermarket pistons. i know a guy who has built 3-4 solid, solid LS-Vtec's with eagle H beam rods and pr3 or p72 pistons. he also built a turbo'ed b16a with stock rods and aftermarket pistons...
Old Jan 13, 2005 | 09:24 PM
j87w's Avatar
j87w
I told some other members on here I was going to buy Eagle rods and use type r pistons and they said it will NOT work.
Old Jan 13, 2005 | 10:21 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
That is what I understand too. I thought you couldn't use aftermarket rods with stock pistons or vice-versa.
And about the cams, there is a slight lope to the idle and they will require some tuning, but they are much more agressive and gains of up to 22 hp are possible on a stock B18C1. But if you are not planning on upgrading the valvetrain, you should stick with the stage 1's and keep the redline around 7-8k.
Old Jan 15, 2005 | 05:11 AM
vinnyzcrx's Avatar
vinnyzcrx
heres a newbe question, what exactly does shotpeened mean?
Old Jan 17, 2005 | 07:36 AM
raiden571's Avatar
raiden571
turning u inside out
buy some new rods, its what i would do, leaves more room for error. ill be a pal and recommend these- http://www.homemadeturbo.com/forum/i...threadid=34377 there a very reliable business, ive bought from them bfore, and there relatively inexpensive
