anyone know where to have rods shotpeened
:dunno: my friend had his LS rods shotpeened cheaply enough that it was worth it to buy ARP rod/main studs to go along with it and he reved his LS-Vtec to 7500 without ever having any trouble...
the going rate is about $100-120 or so for shot peening 4 rods. I'm sure there are other cheaper places, but thats the avg rate.
on top of that, to strengten the ls rods, its recommended to upgrade to ARP rod bolts.
thats about $35-40.00
To use the ARP bolts, you cant just screw them in, you have to machine them to fit properly. If you dont, it distorts the rod bearing area and it goes out of round. This service is another $80 or so.
So that puts you about $250 just to shot peen and strenghten the LS rods.
If you arent planning on making over 250hp, the STOCK LS rods are fine. If you are boosting or making plenty of HP, then you should be going with aftermarket rods like EAGLE rods already.
So to sum it up:
Either you stay with LS rods or go Aftermarket.
Its not worth it to shot peen and strengten the stock LS rods.
So to sum it up:
stock rods cant take 8500 RPMS, dont take your chances, just go aftermarket. Eagle H Beams and Crower Econo Billets are both rods that you should consider, both have a good reputation and are designed to handle rev's like that...
I hate to say this, but I cant really afford aftermarket right now. I know in an engine build that sounds stupid. If I were to go with aftermarket rods then I would have to go with aftermarket pistons also. Im not going to run nitrous turbo or anything on them. The pistons are like $400, then rods are like $350. Thats why I would just rather use my ls rods. It would save me alot of money and time. Im going to use ITR pistons also.
Originally Posted by j87w
So if I shotpeen then will it handle 8500K. Im going to use Skunk2 Stage 1 cams so whatever they build power till is what I wanna rev at.
Thanks
Jared
Thanks
Jared
From what other users of the S2 Stage 2 Cams say is that it has a little bit of lope at idle. I dont know the stage 1's arnt that agressive(a bit more than a CTR) and seem good for a daily driver. Im willing to consider the stage 2s though.
