which head
Old Nov 30, 2004 | 05:19 PM
BoostedITR41's Avatar
BoostedITR41
Originally Posted by dustimus
ITBs..... maybe if he had an extra three grand laying around.
or build your own for 500-1000 bucks
Old Nov 30, 2004 | 09:01 PM
Snoopy's Avatar
Snoopy
been there done that
yea and then the extra $1k or so to get it running right
Old Nov 30, 2004 | 11:11 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Originally Posted by DRfrank
i am going to overbore a b18c to 2.0 liters and put it in a crx, now the thing i want to know is which head is better for PnP and or upgrades, the c1 or c5, i heard that the c1 is basically just a b16 head so i was thinking that the b18c5 head would be a smarter choice, yet more expensive
Are you going FI? If so, all this garbage about ITB is useless to you. The head choice is dependant on whether or not you are going FI. ITR has lower compression and the GSR has higher compression. It is about .2 points difference on a with a stock GSR block and pistons, so it is pretty negligible if you are throwing dished pistons in there anyway.
Old Dec 1, 2004 | 05:47 AM
sherwood's Avatar
sherwood
I missed Sean
i'm goin NA AM
Old Dec 1, 2004 | 08:59 AM
Provocateur
On permanent hiatus
Then go with the GSR head for higher compression.
Old Dec 1, 2004 | 02:47 PM
dustimus's Avatar
dustimus
Better golfer than you
You got it backwards buddy... USDMs ITR has 10.6:1, GSR with 10.0:1.
Old Dec 1, 2004 | 02:51 PM
dustimus's Avatar
dustimus
And another thing.
Garbage with ITB's???? Not necessarily. Look at tony the tigers GSR running high 11s low 12s with ITBS and high boost. True they are hard as shit to tune, but once tuned make WONDERFUL power.
Old Dec 1, 2004 | 03:58 PM
sherwood's Avatar
sherwood
I missed Sean
[QUOTE=Shmoo]Are you going FI? If so, all this garbage about ITB is useless to you. QUOTE]
And another thing.
He said if i wasnt going FI (ie... no boost)
and i think that the gsr head can achieve higher compression... that the ITR head lost compression but gained it back using higher compression pistons.... i think..
Old Dec 1, 2004 | 05:48 PM
dustimus's Avatar
dustimus
and no, the GSR head doesn't make more compression then the ITR head vs. head.
Old Dec 1, 2004 | 08:46 PM
Provocateur
On permanent hiatus
And another thing.
High 11s low 12s isn't something to write home about with a turbo'd car running high boost.
