which head
Old Dec 1, 2004 | 08:54 PM
BoostedITR41's Avatar
BoostedITR41
yes the GSR head will make .2 more compression on a motor than a ITR/B16A head. ITR has a higher dome piston than the GSR that is why it has more compression but put a GSR head on a ITR block you will have closer to 11:1 compression
and no that isn't very impressive for high boost....I know of street tire cars on low boost running that.
Old Dec 1, 2004 | 09:09 PM
sherwood's Avatar
sherwood
I missed Sean
so a 10.2 piston in a c5 is the same as a 10.0 gsr piston in a c1, right? (compression wise)
Old Dec 1, 2004 | 09:32 PM
dustimus's Avatar
dustimus
Better golfer than you
Yes your right, i checked on that. Well I learned something today But yes I don't know the exact times Tony runs, I know he makes a shit load of power and I just figured 11s.
Old Dec 1, 2004 | 09:40 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Umm...I believe I said that in an earlier post. :fawk:
Old Dec 2, 2004 | 10:56 AM
sherwood's Avatar
sherwood
I missed Sean
you little wiseass... lol
so then it will, i'm jsut going to go with the GSR Swap then and hpefully i can find an LS tranny too (i heard it is geared slightly better or suttin?)
Old Dec 2, 2004 | 12:49 PM
BoostedITR41
no LS tranny is better for big turbos cause of longer gears....all motor you are goin to want a ITR or B16A tranny
Old Dec 2, 2004 | 06:37 PM
sherwood's Avatar
sherwood
I missed Sean
ok
