which ecu (ls/vtec)
Old Oct 27, 2004 | 10:39 PM
pomansouth's Avatar
pomansouth
Default which ecu (ls/vtec)
i am gonna do a ls/vtec with a b16a1 head, so do i need a b16 ecu or can i use gs-r. Also can someone give me a parts list for a safe ls/vtec. I just want to make sure i am not skipping anything.
thanks,
Steven
Old Oct 28, 2004 | 02:26 AM
Kai's Avatar
Kai
Rotorphile.
What body?
84-87: aftermarket EMS or serious rewiring.
88-91: PR3 or PW0 and V-AFC, or 90-91 PR4 and RPM switch and S-AFC
92+: P72, preferably with V-AFC
Old Oct 28, 2004 | 05:32 AM
pomansouth's Avatar
pomansouth
heh, i think i got the easy one. its a 94 honda civic.
Old Oct 28, 2004 | 01:04 PM
Snoopy's Avatar
Snoopy
been there done that
like kai said, you can use a p72 or a chipped p28
Old Oct 28, 2004 | 01:15 PM
dubcac's Avatar
dubcac
I
Or a P30 from the DelSol Vtec.
Old Oct 28, 2004 | 05:41 PM
PHiZ's Avatar
PHiZ
BOOST GOD
Originally Posted by Snoopy
chipped p28
yup.
-PHiZ
Old Oct 28, 2004 | 07:29 PM
Mart_it's Avatar
Mart_it
***** God
P28, thats what ive got that would be a good choice for a G3
Old Oct 29, 2004 | 05:28 AM
pomansouth's Avatar
pomansouth
im not a chip fan. I would rather have stock oem maps and so forth in there instead of something that someone just decided would work well. Plus I am gonna turbo some time within my life so what would a chip do me then. Thanks for all of the ecu enlightment, I am sure I can score atleast on of these for a good price.
Old Oct 29, 2004 | 08:59 AM
PHiZ's Avatar
PHiZ
BOOST GOD
Well, by that logic, you shouldn't build an ls/vtec, because it's not oem, it's just something that someone thought would work well.
The P30 is the wrong ecu because, it's a 1.6L.
The P72 is the wrong ecu, because it is optimized for the GSR intake manifold, and GSR cams, with a really low vtec level. Plus you will have to add a knock sensor.
The P73, ITR ecu, would be the closest to a 1.8 Vtec. But those only come in OBD2 flavor, which means additional wiring of sensors.
:shrug:
-PHiZ
Old Oct 29, 2004 | 09:45 AM
dubcac's Avatar
dubcac
I
:shrug:
-PHiZ
The P30 and P72 can both be chipped to work well with an LSVTEC. VTEC point can be changed on the GSR, and the P30 can be mapped with more fuel if need be, although it would run fine on the stock ECU. I too would run a P28 simply for cost factor over the other 2, and they are easier to come by than a P30.
