help! no injector action in crank circuit
Old Oct 7, 2004 | 06:04 AM
while e coyote's Avatar
while e coyote
Default help! no injector action in crank circuit
00 gsr into 94 del sol obd1 p72, no cels. no injector action while cranking. but i can get it to start and run if I lightly dust the air cleaner with starting fluid. warms up, tachs up, no codes... but if I shut it off, it wont start without the dusting. Any idea's?
Old Oct 7, 2004 | 07:18 AM
Running925's Avatar
Running925
Your Powder Coater
is this a fresh swap or did this thing run in the current vehicle prior to this problem?
Old Oct 7, 2004 | 07:20 AM
Running925's Avatar
Running925
Your Powder Coater
ok.. i just skimmed through your other post.. sounds like it could be as simple as a bad fuse somewhere or a missing ground!.. check the obvious stuff first. Best of luck.. i'm sure others will chime in with some suggestions as well.
Old Oct 8, 2004 | 07:30 PM
while e coyote
nevermind... found it the brown 3 wire 5 pin socket that goes to the ud/fb. the retainer came loose and a wire was mostly out
thanks anyway
