transmissions?
Old Aug 27, 2004 | 12:25 PM
g2_teg_na's Avatar
g2_teg_na
^ Visual Learner
Default transmissions?
my question is what are the pros and cons to the separate b-series transmissions? for a g2 integra, which do u think would be best? b16 tranny, GS-R tranny, or LS tranny. can some one explain the differences and what makes them better, or worse. thanks.
Old Aug 27, 2004 | 07:32 PM
g2_teg_na's Avatar
g2_teg_na
^ Visual Learner
LS vs. GS-R. vs. Si
Old Aug 27, 2004 | 08:02 PM
ED9man's Avatar
ED9man
driver
whatever has the shortest gears, ITR tranny I believe.
Old Aug 27, 2004 | 10:23 PM
Civic2Scooby's Avatar
Civic2Scooby
b16a or ITR trans have almost identical gearing, and they would be your best bet...LSD would be nice but not neccesary.
Old Aug 28, 2004 | 03:18 PM
g2_teg_na's Avatar
g2_teg_na
^ Visual Learner
thanks....i hear that an LS tranny will give me higher top end. an Si will give me better acceleration. and GS-R is in the middle. is this true?
Old Aug 28, 2004 | 03:51 PM
Civic2Scooby
more or less yes.
but unless you are making 400+ horsepower I would stick with the shortest geared trannies. (b16a, ITR)
shorter the gears the faster you accelerate...of course the freeway ride will be a big more high reved in fifth, but it is worth it.
Old Aug 28, 2004 | 08:29 PM
g2_teg_na's Avatar
g2_teg_na
^ Visual Learner
thanks. does an LS tranny have any advantages at all?
Old Aug 28, 2004 | 08:46 PM
ED9man's Avatar
ED9man
driver
no, unless you plan on making regular 160+ mph runs.
The shorter the gears the better, it's not going to hurt your motor down the highway as long as you stay off the high lift cam profile, which mean you can cruise all day at 90-100 without worrying, just don't skimp on oil changes or regular maintenance, it shouldn't overheat, the short fifth is nice for some passing oomph, no need to downshift.
Old Aug 29, 2004 | 07:39 AM
g2_teg_na's Avatar
g2_teg_na
^ Visual Learner
so, i wouldnt be able to "cruise down the highway at 100" with an Si tranny? or GS-R?
Old Aug 29, 2004 | 09:49 AM
Kai's Avatar
Kai
Rotorphile.
Remember guys, this is a G2 Integra. That means cable, or a pricey conversion kit.
Your three real choices are first gen B16A (SiR, XSi, RSi,) B18A (normal YS1), or B17A (GS-R version YS1) Given this lineup, the stock B18A trans is the longest, the B16A's fall in the middle, and the B17A trans is very similar to the later ITR trans, very short.
I'd go with a B17A version YS1, though they are getting rare and very expensive.
See this link for the ratios:
http://www.bseries.net/html/specs/btrannyspecs.php
