b20/VTEC being built/ some questions please help.
Old Aug 22, 2004 | 10:07 AM
WhatNow's Avatar
WhatNow
n00b
Originally Posted by Kai
That engine isn't even close to needing resleeving.
think so? ok man.. i've learned this one from personal experience.. and it's also easier to do it before your initial build up... crack that block and you're gonna be ****ed..
Old Aug 22, 2004 | 08:34 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
:eh:
There's no need to sleeve that motor with a goal of only 200 whp. I made close to 300 whp on a stock block and ran it daily. Made some high 12 second passes on it too... where are you getting this 'personal experience' from? :thinking:
Old Aug 23, 2004 | 06:01 AM
PHiZ's Avatar
PHiZ
BOOST GOD
Originally Posted by westcoaststyle
:eh:
Well to be fair, I don't think you were running an 84mm bore. The CRV sleeves are pretty thin, and that's stock.
Also, you're talking about your GSR right? MUCH better R/S means less sidewall loading, and slower pistons speeds.
I don't have an opinion on sleeving vs. not. But I'm just saying you're comparing apples to donkeys.
-PHiZ
Old Sep 13, 2004 | 06:10 AM
pomansouth's Avatar
pomansouth
i was reading the new honda tuning and it was mentioning a b20/vtec and said that there is a problem with valve tap. Said that the releifs arent deep enough in the b20 pistons to let the b18c1 valves extend out without tap. You may want to think about this.
Old Sep 13, 2004 | 12:34 PM
Kai's Avatar
Kai
Rotorphile.
That gets to be more of a problem with higher lift cams, like ITR's. It is still a good safety measure to have them milled out anyway.
Old Sep 15, 2004 | 11:27 PM
JustaSolVTEC's Avatar
JustaSolVTEC
I don't see ARP rod bolts on that list anywhere.....those will be needed.
Old Sep 16, 2004 | 12:22 AM
Kai's Avatar
Kai
Rotorphile.
I kinda ignored it because of the earlier suggestion of Eagle H-beam rods, but otherwise some APR rod bolts would be nice for shot peened stock rods.
hondav6
Aug 9, 2003 05:48 AM
ekjl
7
Jun 23, 2003 07:55 AM
EVOCELICA
Feb 11, 2003 02:39 PM
bluesiTYPER
Dec 1, 2002 12:09 PM
myka7500
Aug 19, 2002 07:20 AM
