ls/vtec converson
Old May 20, 2004 | 12:23 PM
integra93jdm's Avatar
integra93jdm
Default ls/vtec converson
i havew a 93 integra and i whant to do a ls/vtec conversion with a gsr head and typer pistons what other parts whould i need to do a ls/vtec conversion and if i would buy headers whould i have to buy them for a gsr
Old May 20, 2004 | 12:46 PM
Kai's Avatar
Kai
Rotorphile.
There are two different "GS-R" heads, the PR3 (92-93) and the P72 (94-01.) Pick one. It should be complete from the throttle body to the head gasket.
-New B18A head gasket
-New B17A/B18C head bolts or studs
-1/8" NPT plug, tap, and teflon tape
-full LS/VTEC oil line kit
-Stock exhaust or 92/93 non-GS-R upgrade exhaust parts
-shotpeened stock rods or aftermarket forged rods
-rod modification to fit P73 pistons
-New B16/17/18C oil pump would be nice
-New B18C timing belt
-New B18A water pump
-Some OBD-1 DOHC VTEC ECU or an RPM switch
-More stuff I can't recall
-Plenty of time.
Old May 27, 2004 | 07:49 AM
LSVTECKING's Avatar
LSVTECKING
rebuilding
Dont get your stock rods shotpeened that shit is pointless if you build an lsvtec. Just indulge in a new set of rods..much more relieble. Make sure you get rods for an LS though.
Old Jun 7, 2004 | 11:01 AM
B20powered's Avatar
B20powered
You can't see me
A B18a (LS) water pump will not work with a B18c (GSR) timing belt. Get both either GSR or Type-R water pump and timing belt.
Old Jun 16, 2004 | 07:58 PM
BassmintPimpin's Avatar
BassmintPimpin
EBP'n It!
A lot less headaches if you buy the Golden Eagle LS/VTEC kit. No machine shops.
CiViC2nR86
7
Nov 10, 2003 07:35 PM
STEALTH_GSR
Engine Swaps, Tech & Tuning
8
Jun 26, 2003 08:48 PM
hyperlite
20
Jun 16, 2003 07:57 PM
DvSrOmE
7
Dec 14, 2002 09:51 PM
HeavyCivic
92+ Civic/EL & Del Sol
13
Oct 1, 2002 02:37 AM
