Wastegate leak
Old May 12, 2004 | 10:21 PM
boosted lude's Avatar
boosted lude
Default Wastegate leak
Ok... I have the fmax turbo setup on my 01 prelude... ever since ive had the kit on the car the wastegate has always started leaking at the manifold... I have a bran new tial wastegate and had my manifold takin off and the mounting flange machined so it was perfectly flat... but yet it still leaks out of the same spot on the manifold... No matter how many gaskets you put on there 1,2,3 it doesnt matter... the gasket just burns up and starts leaking... Im all out of ideas to fix this problem... ANY SUGESTIONS WOULD REALLY HELP... Thanks
Old May 13, 2004 | 06:06 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
Did you put the aluminum ring into the wastegate flange where it mounts up? It should fit inside of the bottom flange.
If you did, have you tried some copper high heat gasket sealer?
I use the gaskets sold here: http://www.roadraceengineering.com/tial.htm (very bottom of the page)
The ones that came with my turbo kit burned up quickly and leaked like you said. These have not leaked yet and I also use the copper sealer.
hih
Old May 13, 2004 | 02:38 PM
1stGenCRXer's Avatar
1stGenCRXer
GWAKS- Tech Geekifier
Good ole copper gasket RTV should solve your woes.
-Harry
AIM: NDcissive
civicfan8
92+ Civic/EL & Del Sol
11
Apr 1, 2004 09:43 AM
DavE96GsR
12
Mar 2, 2004 09:49 AM
Doc Gyneco
3
Jan 7, 2004 07:36 AM
agent87
21
Jan 7, 2003 09:32 AM
kilabeez
Prelude
Nov 22, 2002 03:56 PM
