Problems with Suggestions?
Old May 18, 2004 | 09:39 AM
Civic2Scooby's Avatar
Civic2Scooby
Originally Posted by Running925
humm.. didn't realize that.. or really think about it before i started hacking away at my car harness.. i guess we'll c what happens with this wiring issue & if it comes down to that i'll just replace the car harness & convert it to obd-1 ... I'll probly dive back into this wire mess tonight so i'll let u guys know how it goes..
if you ever need somebody to build/modify your harness and go to obd-1 just holla at me...I am always down for a road trip, and would love to see your car...:goodjob:
Old May 18, 2004 | 11:06 AM
Running925's Avatar
Running925
Your Powder Coater
We might have to get together one day anyways just for the hell of it! Theres always stuff goin on around here & we could just start powder coating misc. things on your car! lol
Old May 18, 2004 | 04:07 PM
Civic2Scooby
I am always down for a mad powder coating session....:bigok:
Old May 18, 2004 | 07:25 PM
Running925's Avatar
Running925
Your Powder Coater
ok went to wire up everything under the hood tonight & that seemed to go really well.. i plan to do the ECU tomarrow... only thing strange that i ran into is that i can't take my key out of the ignition unless the battery terminal is unpluged..
i'm guessing it's got to do with the automatic tranny that came out of it.. probly like a safty thing that doesn't let the key come out when it's not in park.. if anyone knows what wires deal with this or how to fix.. toss some info my way so that things go smoother tomarrow!!
Old May 19, 2004 | 10:46 AM
Running925's Avatar
Running925
Your Powder Coater
Anyone know what color the Park / Neutral safty switch wire's are on an automatic 95 ex... need to cross them or complete the circuit so that it can allow the car to crank! ???
Old May 20, 2004 | 09:20 AM
Andy's Avatar
Andy
Hybrid Forum Moderator
From my limited knowledge of auto/manual swaps, you need to take the cable from the automatic shifter and slide it into either park or neutral and then hotglue the sucker into place. I'm assuming there is some sort of sensor built into the system that won't let you crank the engine over unless it's not in gear. The shop I talked to, who've done auto/manual swaps say they usually leave the cable there, just out of the way and locked into place. I haven't done one myself, so I dont' know for sure. Good luck with it.
Old May 20, 2004 | 09:34 AM
Running925's Avatar
Running925
Your Powder Coater
already taken care of but thanks!.. i crossed the switched wire & soddered it into the park wire!
Old May 20, 2004 | 09:37 AM
Andy's Avatar
Andy
Cool. How close are you to getting it started?
Old May 20, 2004 | 09:46 AM
Running925's Avatar
Running925
Your Powder Coater
i've got everything under the hood wired up & i almost have the ecu finished.. i tested my starter by turning the key to the crank position & the starter spins so all i've got to do is finish up the ecu wireing & put my fuel rail & injectors in / hook up my fmu / & finish some vacume lines & i should be able to fire it up.. as long as i get the ecu wiring finished up tonight i should be able to fire it up.. i'm extremly close to being finished.. hope to be driving it this weekend!
Old May 21, 2004 | 05:41 AM
Running925's Avatar
Running925
Your Powder Coater
Just realized that i was missing the 2 things that i need to fire up & drive my car last night..
1. Resister thing for injectors
2. Rear Motor Mount.. somhow almost forgot.. Not the mount it-self.. but the peice of metal that connects the engine to the mount! (i can barrow one from a friend for the week but does anyone have one laying around that i could purchase??)
