Vtec
Old Apr 21, 2004 | 08:06 PM
kevo2k6's Avatar
kevo2k6
Default Vtec
can u run a vtec engine without the ecu and juss a vtec controller? is does the ecu run vtec?
Old Apr 21, 2004 | 10:03 PM
dustimus's Avatar
dustimus
Better golfer than you
Originally Posted by kevo2k6
can u run a vtech engine without the ecu and juss a vtech controller? is does the ecu run vtech?
Taken from www.acura.com
The hallmarks of all Acura engines are smoothness, low emissions, high power output per liter of displacement, lightness and impressive reliability. To achieve these aims, our engineers have developed a number of innovative patented systems. Among these is the Variable Valve Timing and Lift Electronic Control (VTEC™) system. This technology solves the age-old compromise between tuning an engine for peak torque or peak horsepower, and provides the best of both worlds. With VTEC, the engine delivers ample low-rpm torque and high-rpm power without sacrificing either, while delivering surprising fuel efficiency. Other engine features that bear out the legacy of Soichiro Honda are lightweight aluminum construction, overhead cams, and four valves per cylinder for maximum efficiency and outstanding performance. From the beginning, and for good reason, the engine has always been the heart and soul of the Acura automobile.
Old Apr 22, 2004 | 07:02 PM
SunsetLude's Avatar
SunsetLude
Why wouldnt you want the ECU???
Old Apr 22, 2004 | 08:38 PM
kevo2k6's Avatar
kevo2k6
i do want the ecu i was juss wonderin if u can use vtech without the comp because it is a possibility i might go carbed and bypass as much of the comp as i can. but i would love to be carbed and still have vtech.
Old Apr 23, 2004 | 01:10 PM
MrFatbooty's Avatar
MrFatbooty
Wannabe yuppie
You can run a VTEC motor without a VTEC ECU, assuming you have an RPM-operated switch to trigger the VTEC solenoid and some way to get enough fuel into the motor at high rpm.
One unique feature of the VTEC ECU is that VTEC engagement point is not totally fixed. It is a function of rpm and engine load. That means if you're crusing along the highway in a low-ish gear and not putting much of a load on the motor, it will stay out of VTEC but then if you floor the throttle it will switch to the high cams.
If you want to run it with carbs, then essentially the carbs will automatically correct for the increased airflow when the high-rpm cam profile comes on. Using an rpm-activated switch to trigger the VTEC solenoid instead of a VTEC ECU will give you a bit less precise control, but it can work.
AcuraFanatic
Accord
15
Sep 20, 2005 08:22 PM
accorduk
Engine Swaps, Tech & Tuning
41
May 2, 2005 10:44 PM
blackandblue
92+ Civic/EL & Del Sol
6
Jan 11, 2004 07:18 PM
Tirod
Nov 22, 2003 01:08 AM
onelowhatch
CRX & Pre 92 Civic
17
Jul 5, 2003 03:24 PM
