ls/vtec coversion or gsr swap
Old Mar 2, 2004 | 03:19 PM
integra93jdm's Avatar
integra93jdm
Default ls/vtec coversion or gsr swap
should i go with a gsr head and pistons or just do a whole swap
Old Mar 2, 2004 | 07:17 PM
Andy's Avatar
Andy
Hybrid Forum Moderator
Here's my thoughts on this. In order to build and LS/VTEC to the point that it will be powerful enough and just as reliable as a B18C1 swap, your going to have at least the same amount of money into it. Since you'd be rebuilding a bunch of the LS block anyway, you could run better components than the factory offers and have a superior engine than a stock B18C1, but most likely for more money. The reliablity is only as good as the parts and who put it together as well.
I would usually only suggest a LS/VTEC swap if you already have an LS engine and don't want to invest the money into a new block. If your starting from sratch, your better off starting with a B18C1 (in my opinion).
Snoopy's Avatar
Snoopy
been there done that
yea how much you have to spend and what car this will be going into helps a whole lot
Old Mar 3, 2004 | 08:57 AM
integra93jdm
going in to a 93 integra
Old Mar 3, 2004 | 07:50 PM
å's Avatar
å
åhhhhh
id say LS/VTEC.. if you have the money to get a GSR swap, then just get the LSVTEC and spend the money you save on building the block etc... it willget you more power
Old Mar 16, 2004 | 12:41 PM
SSCivic's Avatar
SSCivic
Swolen Member
I run a B18C1 in my 2000 Civic and I love it. Depending on where you get your engine and where you get it put in, it may cost less and be more reliable than an LS/VTEC. I love my B18C1.
Old Mar 17, 2004 | 04:04 AM
vtec28412's Avatar
vtec28412
b18c1 all the way. I love mine.
Old Mar 26, 2004 | 08:00 AM
Mr. UnderHill's Avatar
Mr. UnderHill
Love Is Suicide
Perfectly said :goodjob:
Old Mar 29, 2004 | 02:05 PM
Dose3782's Avatar
Dose3782
Boost is like crack
Hiyas,
I can see the point of both sides on the LS/Vtec. I've seen LS/Vtec's that smoke badly and leak oil as the result of improper drilling for the dowels. I've seen the wrong size of lines ran etc. etc. I personally lean toward the LS/Vtec prop because I have one in the build proccess. I can tell you dollar for dollar that my build has been cheaper going the LS/Vtec route. I say this because I shopped around and found better deals buying the b18b block and the b16 head cheaper, tranny, etc than buying a whole running swap. I am building for boost, so yea I replaced alot of stuff. I guess if your going for just a stock engine, then yeah buy the whole swap. If you want to make some serious HP and have the money and know how go LS/Vtec, as you can get the base stuff cheaper and then add the goodies... But all in all you spend a crap ton of money either way lol *imho*
Old Mar 29, 2004 | 03:37 PM
qtiger's Avatar
qtiger
GSR swap. LS tranny blows.
