How to Increase Torque on H22A ???
Old Mar 5, 2004 | 08:08 PM
a1p2003's Avatar
a1p2003
Default How to Increase Torque on H22A ???
The horse power to torque ratio seems a bit low on the torque end. I was wondering if anyone new how to increase the torque on the H22a JDM engine. Any suggestions would be greatly appreciated.
Old Mar 6, 2004 | 08:34 AM
yellow civic ex's Avatar
yellow civic ex
ghey slow d16 modder
the most obvious method would be to use a supercharger like the jrsc. that would give you quite a bit more torque and even out the ratio a bit.
almost all of the N/A stuff that you can do would probably up the horsepower a little more than the torque and throw the ratio off even more.
Old Mar 8, 2004 | 06:55 AM
ludeboom's Avatar
ludeboom
lets not forget that on an NA motor, the torque output is directly related to engine displacement. and we are talking about a 2.2 liter here, not some 3.5 liter V6. remember that the h22a makes excellent torque for its class of motor. cams and head design also play a role.
but yes, forced induction is just that...it forces more volume of air (displacement) by increasing pressure.
laws of physics
therefore a smaller 4 cylinder engine can "simulate" a V8 engine's displacement, by using a turbo or supercharger to force more air thru the combustion cycle.
edit: cam gears and fuel pressure adjustment should allow you to get some more torque outta that bitch in low to mid range powerband.
~boom
Old Mar 8, 2004 | 12:14 PM
a1p2003's Avatar
a1p2003
What about reprogramming the ECU ?? Will that have any effect on torque gains? Anyone know of a shop in the LA area where they drop engines as well as reprogram ECU's ?????
Old Mar 8, 2004 | 01:49 PM
ludeboom's Avatar
ludeboom
ha
im sure there are tons of places all over cali, i live in NY i do things in my driveway and yard.
Old Mar 9, 2004 | 07:54 AM
alphaxxn's Avatar
alphaxxn
4500rpm hesitation
Max Ha Racing is near LA and im a huge supporter of him, he does custom chips, and swaps.
LilDragonTKD
92+ Civic/EL & Del Sol
9
May 9, 2003 05:51 PM
eclipse spanker
14
Dec 2, 2002 08:17 PM
Widebody NSX
Nov 7, 2002 07:18 PM
