Engine wizards -- can you call this one?
Old Mar 13, 2004 | 04:46 PM
ChrisGSR's Avatar
ChrisGSR
Originally Posted by ludeboom
that parts website isnt accurate guy, at no point is honda at fault here, the honda part numbers were different. that belt part # from the SKU is probably not a genuine honda belt. if it is genuine than again its the wholesalers fault or whoever put in the SKU code.
and ebay is ebay
~boom
Agreed, that the site I checked with isn't accurate. But it is a site run by a fully authorized Honda/Acura dealer, though, and everything in their catalog is genuine Honda/Acura stock.
I also obviously agree with you that the staff at this dealer site messed up the SKU transcription. But I continue to maintain that Honda's part numbering system is a problem here. A part that looks similar but isn't functionally compatible needs to have not only a different part number, but a visibly much different part number.
And other non-part-number codes should not be shared across similar-but-incompatible parts. Both the GSR and the Type R belt say "126RU26" on them, in the largest lettering on the belt. Easy to make a mistake.
The LS/RS belt says "125RU26". That reflects good practice. Greatly reduced risk of a mixup with a GSR 126RU26 unit.
If they had carried over that nomenclature and changed the leading numeric, I would have looked at my old GSR belt, which says "126RU26" and then looked at the R belt saying "127RU26", and that would have been much more obvious. And I probably wouldn't have wasted any time at all on this matter.
As noted, other people are obviously experiencing the same confusion as I did (including probably some parts desks in the dealer network).
As far as ebay goes, I've bought lots of parts there and have only rarely had bad experiences. I have never been burned by any seller with 100% positive feedback and over 50 sales. People who have worked that hard to build a good record are pretty protective of it.
Anyway, following up on the trick to artificially tighten the belt by pulling on the tensioner spring during the tensioning procedure -- it seems to have worked as intended. Engine has been running fine and making good power from idle to redline. I'm still mildly nervous about pushing this hack hard, and I will probably put a proper GSR belt in the engine in a few weeks, but for now the car runs happily.
Old Mar 13, 2004 | 10:07 PM
ludeboom's Avatar
ludeboom
The LS/RS belt says "125RU26". That reflects good practice. Greatly reduced risk of a mixup with a GSR 126RU26 unit..
lets think about those numbers.
the LS/RS belt is a non-vtec head
the GSR is a VTEC head
the ITR is a VTEC head
in fact the GSR and ITR head are very similiar, and are also probably of a similiar casting. meaning that is why they have the same initial part #
but again ITR definitely has different cams, so i would imagine that small differences between two similiar motors...like cams or cam gears...would translate into a small numerical difference in part numbers.
~boom
Old Mar 14, 2004 | 01:31 PM
TheRooster's Avatar
TheRooster
Former Senior Member
Maybe a CRX engine belt? It's a B-series with Vtec and the deck is just a weeee-bit taller than the GS-R and the Type-R.
Good luck on the tapping problem. My car suffered from this for about a year until I finally got so tired of it and the shoddy machine work I had done to try to fix it that I had to junk the block and bought a B18C from japan. Keep looking though. Ensure your valves are checked good and that there's no flat spots on the cams. Compression and leakdown checks are great too. Take a crack at it and don't get frustrated. It's general advice, but it's very easy with a problem like this to get frustrated and start making mistakes.
RaVen_CiviC
92+ Civic/EL & Del Sol
34
Sep 24, 2004 06:11 PM
se93
Engine Swaps, Tech & Tuning
Jul 4, 2003 07:56 AM
98CoupeV6
News & Rumors Archives
16
Jun 19, 2003 03:10 PM
Tirod
31
Mar 3, 2003 05:13 PM
jaje
Jul 11, 2002 08:01 AM
