Best Engine for Boost?
Old Feb 18, 2004 | 10:33 PM
Skad's Avatar
Skad
Worst Poster Eva
Default Best Engine for Boost?
Which engine is best to boost? There's all this talk about compression, etc, blah blah
So which does the best and has the most Turbos made for them?
Old Feb 19, 2004 | 12:07 PM
white_n_slow's Avatar
white_n_slow
it's my D in a B
you can match just about any turbo with just about any motor... not to say it will work well.
If youre keeping the motor stock, a b18b is probably the safest (moderate compression, thick sleeves). If youre building, you can safely turbo any motor.
Anyway, very vague question... try a search?
Old Feb 19, 2004 | 04:55 PM
1stGenCRXer's Avatar
1stGenCRXer
GWAKS- Tech Geekifier
From the forum rules:
Please no "which is better?" posts. Nothing is flat-out better than anything else. Give an outline of what you're trying to achieve and what other parts you're going to be using.
This is your one-time shot to come up with a narrower topic of inquiry, otherwise this will be locked.
-Harry
AIM: NDcissive
Old Feb 20, 2004 | 05:56 AM
LSVTECKING's Avatar
LSVTECKING
rebuilding
If you want the best motor to turbo it has to be the B20b it has 8.8:1 compression. wat better than the ls
Old Feb 20, 2004 | 06:08 AM
1stGenCRXer
Ok, things like this are exactly why we don't have "which are best" threads. The B20b/z is the same block casting as the B18b. If you look solely at compression ratio when choosing an engine for boost, then you really aren't educated enough on the subject to make a valid decision.
The B20 has very thin cylinders from the factory, and of the same type as the B18b. In fact, it is much more reliable to start with a B18b, sleeve it and then bore it out to 2.0L if you're worried about displacement, than it is to start with a B20 and slap a turbo on it thinking you're golden.
The B20 is a fine engine, but it is definately not topping the list of my choices for a boosted platform.
-Harry
AIM: NDcissive
Old Feb 20, 2004 | 11:44 AM
white_n_slow
it's my D in a B
exactly what I was going to say. The b20b can only handle very small doses of boost before you have to start worrying about cylinder wall/sleeve integrity. Either motor would be fine sleeved, but then, if youre building the block, you could go with any motor and build accordingly.
Old Feb 20, 2004 | 08:03 PM
Skad's Avatar
Skad
Worst Poster Eva
K, sorry for being the newb.
Where's a good site to look at Honda Motors and their HP ratings (and pricing).
Basically, could I get a B16 (the one with 170hp) and then boost it later? What all would I have to do to it in order to 'safely' boost it? What are the steps and prices..?
Thanks guys.
Old Feb 21, 2004 | 12:14 PM
txhatch's Avatar
txhatch
I hate 2003 Noobs.
You can turbocharge any motor. To keep any engine running smoothly you will need to tune it using some kinda of fuel management. Most kits come with a an fmu which will work, but a standalone allows for better tuning. For best bang for your buck i would go with ls turbo. Yes it doesnt start out with the same amount of hp as a b16 but it has more displacement and can take a lot of punishment. I have seen about the same hp numbers on the same psi for both. And if you blow the b18b another longblock will only cost about $800 at most.
Old Feb 21, 2004 | 08:53 PM
Kai's Avatar
Kai
Rotorphile.
4G63. Cast iron, baby.
If you want my honest opinion of what the "best" engine is to turbo, I'd tell you it's the biggest displacement one you can afford to turbo. Pretty much all Honda blocks need stronger sleeves to hold up to any serious amount of boost, so all things considered the only real difference is the inital investment in the block.
Old Feb 23, 2004 | 05:59 AM
cashizslick's Avatar
cashizslick
Ya, B18B is the best for boost - compression really isnt that big of a difference between this motor and the B20 - its all in the sleves like he said
RaVen_CiviC
92+ Civic/EL & Del Sol
34
Sep 24, 2004 06:11 PM
se93
Engine Swaps, Tech & Tuning
Jul 4, 2003 07:56 AM
98CoupeV6
News & Rumors Archives
16
Jun 19, 2003 03:10 PM
Tirod
31
Mar 3, 2003 05:13 PM
jaje
Jul 11, 2002 08:01 AM
