Engine Swap Help
Old Feb 10, 2004 | 09:25 PM
slammedcivic99's Avatar
slammedcivic99
Default Engine Swap Help
I have a 99 Honda Civic HX and I want to swap to a B18c Type R but can I still keep it an auto and get a new tranny? What would I need to complete teh swap? Please help me out!! Thanx!!
Old Feb 11, 2004 | 05:19 PM
white_n_slow's Avatar
white_n_slow
it's my D in a B
hybrid forum is that way ---->
So you want an auto b18c5? :eh: I'll just keep my mouth shut.
Old Feb 23, 2004 | 06:03 PM
eGsr's Avatar
eGsr
User
If thats what you want, then you'll have to get a auto b series tranny.
But I recommend doing the conversion to stick. not that bad on an Ek
Old Feb 24, 2004 | 08:11 PM
RiGgEdB18B1's Avatar
RiGgEdB18B1
B18B1 is the best!
LOL...Y would you do that to the B18C5 motor...
Old Feb 25, 2004 | 08:50 AM
ludeboom's Avatar
ludeboom
maybe he wants a really fast automatic
~boom
Old Feb 25, 2004 | 09:04 AM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
It could be that he has an auto now, wants to swap, but doesn't want to do the manual swap with it. It kinda makes sense.
The only problem that I foresee is deciding which ECU to use. I know that manual and auto ECUs are different and that the TypeR didn't come as an auto. Andy or PHiZ may be good people to ask about this.
As for the mechanical part of this, any auto Bseries tranny will bolt up to the motor.
Old Feb 25, 2004 | 09:34 AM
Andy's Avatar
Andy
Hybrid Forum Moderator
The auto will bolt up, but to my knowledge, your stuck with an LS automatic tranny. Supposevly there are B16A automatics in Japan, but I haven't seen one sucessfully swapped into a Civic yet. I know one guy who did an LS swap auto to auto and he had to replace the entire in-car harness with that from an Integra to make it run (it wasn't fun). Since your Civic is an EK ('96-'00) you probably wont' even have the option (the wiring harness is much different that the EG and DC chassis). As westcoaststyle posted above, you'd also be hard pressed to find a computer to run your new engine. Even a B16A/auto computer would have an 8000 rpm redline and hurt your performance.
Bottom line, if you want to stay an automatic, stick with your D-series engine. If you really want performance, a small turbo system or nitrous setup will help, but I'd say it's just a matter of time before the tranny goes boom. Consistant fluid changes and being careful to not overheat the thing will help but it's not designed to handle a lot of power. If you want to swap over to a manual, that's a different story and probably the best solution (that or selling your car and starting with a manual version) if performance is high on your list.
Oops, I just noticed you have an HX. I really wouldn't considering pushing a lot of power through a CVT tranny, it most likely just can't take it. You might consider a D16Y8 ('96-'00 EX engine) swap and use that automatic. I don't know what's involved with that swap specifically, but probably wouldn't be too bad. Get a much more efficent VTEC system and extra 12hp right out of the box, and far more potential but honestly, I'd consider starting with another base car.
Old Feb 28, 2004 | 09:25 PM
slammedcivic99
yeah I would swap to a EX motor because I was afraid that I can't do the high performance engines and keep the same tranny or else I would have to do the whole thing over again and that would cost to much. How much would it cost to do a tranny conversion?? but thanx for your advice, i will take up on the EX motor and do more to that.
vlad
Jan 2, 2013 10:30 AM
bboygraphix
Engine Swaps, Tech & Tuning
3
Jul 12, 2006 10:01 PM
lrcs
Accord
6
Feb 10, 2004 06:14 AM
arctic_giraffe
92+ Civic/EL & Del Sol
29
Aug 11, 2003 09:08 PM
jaje
News & Rumors Archives
Jul 11, 2002 08:01 AM
