radiator hose inner diameter reduction
Old Feb 4, 2004 | 07:20 PM
sspire's Avatar
sspire
Default radiator hose inner diameter reduction
i have a 92 civic VX ( :barf: 1.5 SOHC E-vtec stock) with a b18b. my problem is the fact that LS hoses are like 1 1/4 while the connections on my radiator are 1 1/8 i have aboslutly NO clue on how to deal with this problem, if anyone can help please do this project has taken WAY to long
Old Feb 4, 2004 | 08:56 PM
qtiger's Avatar
qtiger
I would solve it with hose clamps. :naughty:
Actually, this is a little ghetto but if you buy a straight section of 1 1/8" coolant hose and chop it short, you can put it on the radiator and then slip the 1 1/4" hose over it.
Again, be generous with your hose clamps to prevent leaks. I'd use the screw type instead of the OEM squeezies. That way you can ensure it's nice n' tight.
BTW, that tiny little stock VX radiator may have some issues cooling the b18b if it's the same as my CX radiator was (which I think it is). Might want to upgrade to a beefier unit, even if it's just the OEM SI radiator or an Integra radiator.
Old Feb 5, 2004 | 10:42 AM
sspire's Avatar
sspire
ok, i have already tried resizing the hose and the 1 1/8 will not fit. i already have a radiator for a 94 del sol w/ b16a and its connections do not fix my problem. i have not looked at integra radiators wut im pritty sure that they wont just bold up to my civic. so i think i am going to have to just use the screw clamps. appreciate the reply and if any one can give me some more tips it is greatly appreciated( prefrable about teg radiators). :cheers:
Old Feb 6, 2004 | 12:59 PM
qtiger's Avatar
qtiger
The integra radiators do fit but don't directly bolt up, you have to adjust the lower mounts if I remember correctly. I'm sure if you do a bit of searching you'll find a how-to on it. Also, you'd be saying goodbye to your AC if you have it, as the teg radiator is full width.
PHiZ
Aug 17, 2003 10:28 AM
3 plus 1
Aug 13, 2003 08:10 AM
DarkSideAccord
Accord
9
Jun 8, 2003 10:35 AM
97integraLS
6
Mar 5, 2003 03:42 PM
two-steps
Engine Swaps, Tech & Tuning
4
Sep 7, 2002 12:14 PM
