Need Help Installing Head....
Old Dec 30, 2003 | 12:09 PM
integboy97's Avatar
integboy97
Default Need Help Installing Head....
my timing belt went out a couple of weeks ago and i had this shop replace it and they said when the belt went out, i bent 4 valve stems and so i was able to get a replacement head from another 97 integra non vtec with close to the same amount of miles on it. well i have all the basic tools and a torque wrench but i was wondering what else i will need? is it neccessary to replace all the gaskets? someone told me to replace the timing belt again even though its only been like 2 weeks:dunno: also, does anyone know where i can find the torque specs for my head? any and all help would be great:thumbup: also, how long will this usually take to complete? oh, this might sound stupid but should i adjust the valves before i install the head or after its on the block? thanks again:goodjob:
***Cliffnotes***
im installing a new head on my integra. i need help and suggestions!
Old Dec 30, 2003 | 01:00 PM
Mac8008's Avatar
Mac8008
You have to replace all gaskets, but you will still use your T-belt.
Check this link out:click here
Old Dec 31, 2003 | 10:17 AM
integboy97's Avatar
integboy97
thanks a lot! im gonna order the gaskets today and hopefully get working on this:thumbup: hopefully the dealer will have the gaskets in stock and i can start tomorrow on my teg thanks again
Old Dec 31, 2003 | 11:47 AM
ludeboom's Avatar
ludeboom
get the top end gasket kit
change the timing belt and tensioner
get it all here
:edit: oops im stupid, thats honda parts only :edit:
dont mess with the belt that those guys installed, cuz guess what...if it breaks premature you aint gonna be able to cry to them after you touched it
get a shop manual of some sort, for the procedure and torque specs.
one of these is fine for what ur doing
helms($90)
chiltons($15)
haynes($15)
Old Dec 31, 2003 | 12:58 PM
westcoaststyle's Avatar
westcoaststyle
Still here... sorta...
You really don't need to replace the timing belt.
You can just replace:
intake manifold gasket
exhaust manifold gasket
coolant
head bolts (you can get ARP studs from Summit for ~$100)
head gasket
The haynes manual had everything I needed in it as far as torque specs for my rebuild so it'll work just fine for this.
hih
