Drag Strip From the staging lanes to the finish line, this is the spot for on-track drag racing discussion.
Help! I've been owned. . . thrice!
Old Feb 28, 2004 | 08:01 AM
kenton's Avatar
kenton
Change sig? Lose [quote]!
Originally Posted by senseiturtle
As far as launching.... Optimal brake-torquing is as follows:
1-Put the car in Neutral.
2-Rev to 3-4k RPM, and jam HARD on the brake at the same time. You'll find that the brake will grab "harder" when engine rpm's are high, since the fluid pressure is allowed to build up. The pedal should sink an extra inch or two... you'll notice it.
3-Now you're at the strongest braking power possible.
4-Put it in drive, without letting off the brake.
5-Rev the engine to the appropriate launching Rev's.
6- Release the brake and floor it at "GO".
Before I start this post, I wanted to say I did see the part about breaking the stock torque converter. Would you say that only doing this once in a while, or as much as once a weekend would cause it to die?
Anyways, on step 2, as I'm in N and revving to 3-4K. When I push the break down, it'll go down further than just normal braking at idle?
Also, on step 3, when I'm at the "strongest breaking power possible" and I put it in drive, am I revving the engine still? Or do I not rerev the engine to between 3-4K until I'm in D3 with the brake still pressed from when I was in N?
In short (this is how I caught it)
1. Line up
2. In Neutral, rev engine to 3-4K, press break as hard as possible while revving
3. (While brake depressed) Drop to D3, match revs from power braking
4. When flagged, release the brake and hope your automatic can pull something out of the air?
Old Feb 29, 2004 | 12:04 PM
senseiturtle's Avatar
senseiturtle
euro trash
All depends. You're adding un-needed stress. It could work great 1000 times, and break on the 1001st. Or, it could break the first time you do it.
Yes. Increased fluid pressure allows harder clamping. You will feel the pedal depress farther.
Do the thing in neutral, and HOLD the pedal down in that "deeper" position with your left foot. Put in Drive. Rev the engine up to your chosen starting RPM. Wait for signal. Release the brake, and floor it.
you MUST be at idle rpm's when shifting from N->D . Yes, you re-rev while in D. If you go from N->D while giving it gas, you will break it. That's called a neutral-drop, and let me say it again... YOU WILL BREAK SOMETHING.
Practice to find that key RPM. You want the tires to sqeak a little, and have the engine to not bog down and pull itself up and out.
Old Feb 29, 2004 | 04:37 PM
kenton's Avatar
kenton
I raced an Eclipse Spyder GS (2.4L I4, stock) (95-99) last weekend and didn't use the powerbreak method and got destroyed. I raced him this weekend using your advice and I'll just cut and paste what I posted in my livejournal:
I tore him a new asshole off the line, I'm serious. The last time we raced he DESTROYED me. Anyhow, I was trying a new style of shifting tonight and decided to leave it in D3 and just floor it. Anyhow, I FORGOT I was in D3, shifted to 4th thinking it was 2nd, then shifted to NEUTRAL thinking it was 3rd so I hit my REV LIMITER (horrible noise and the car refuses to go) and once I realized what I had done he was already pulling on me and BARELY GOT ME BY A NOSE. I swear, if I wouldn't have ****ed up shifting, it would've been over. I really figured out tonight how to launch an automatic though, and in the future, I'm just going to shift manually so I don't **** up and forget what gear I'm in.
I know, I know. I messed up BAD by hitting my rev limiter. I think it bounced twice before I was able to get it back in a drivable gear. Anyhow, I did A LOT better (albiet was hard on my car), but it's all a learning experience. And hey, if the transmission goes out for some reason in the future, it's all the more reason for a 5spd swap.
Old Feb 29, 2004 | 04:58 PM
wedley2's Avatar
wedley2
bboy Wesley West
but dont waste a transmission just for the heck of it, just swap it out now so u can learn how to drive a stick now...
trust me manual is so much better.
Old Mar 5, 2004 | 10:29 AM
Dave-ROR's Avatar
Dave-ROR
RAD owns.
"Unlawful activities will not be discussed in the forums." - TOS.
Jessica
Sep 13, 2003 06:57 AM
clickwir
Aug 10, 2003 12:26 PM
clickwir
Jun 28, 2003 03:08 PM
Legend_master
42
Jun 25, 2003 05:09 PM
