Honda Accord 98-02: Brake Pad Replacement
Old Mar 28, 2008 | 07:17 AM
  #41
matttttttt1's Avatar
matttttttt1
Default Can't see the pictures for Front brakes job
Anyone knows why?
Old May 5, 2008 | 07:45 AM
  #42
nyakavt's Avatar
nyakavt
Pics aren't showing up anymore. Can somebody reupload?
Old Oct 6, 2008 | 10:47 AM
  #43
wjyiv48's Avatar
wjyiv48
Is a 2003 RSX any different from an Accord etc. in replacing rear brakes?
Old Oct 27, 2008 | 10:46 AM
  #44
vikra007's Avatar
vikra007
Originally Posted by jschmid
Not trying to beat you to the punch 01ACCORD, just thought it might help you out a little (although, like you said, it's a straightforward DIY)
Here's mine:
Since I had the wheels off, I popped in my new centercaps:
I can not see any images now. Can someone repost them? or point me to a diy with pictures for 98 Accord EX?
Old Jan 15, 2009 | 03:52 PM
  #45
k man's Avatar
k man
i am looking for pics showing the rear brake pad change for 1999 accord. any chance someone could post them??
thanks,
k man
Old Mar 21, 2009 | 06:31 PM
  #46
randymanmsu's Avatar
randymanmsu
Thanks for the info on this thread. It's my first time changing honda brake pads and I would have never known to screw the piston in (my wife's ford had the type of piston you had to push back in). Anyway, this info made the process go super fast and easy. Thanks!
Old Nov 10, 2009 | 05:55 PM
  #47
psudrew's Avatar
psudrew
thanks for the pics of the rear brakes on the 2000 accord EX 4 cyl. I'm looking for the same for my 2001 accord EX V6. Is it the same configuration? Thanks.
Old Aug 19, 2012 | 08:46 AM
  #48
audionut's Avatar
audionut
2000 Honda Accord 2 litre 107000 miles.
I’ve just changed the front brake pads. Easy job (usually). However, this time I find that the pedal acts as though there is air in the system, yet the level in the master cylinder never went below minimum when I removed excess fluid. It feels solid with the engine off, but goes to the floor with it running.
In the past I’ve simply pushed the piston in with a G clamp, but some videos I’ve seen clamp the brake hose and release fluid through the bleed nipple. Should I have done that and why? Have I damaged any part of the braking system by pushing the fluid in reverse? Any ideas where I go from here? I tried bleeding them, but to no avail.
Old Oct 14, 2025 | 06:19 AM
  #49
daryelcorran's Avatar
daryelcorran
how do you know when you need to replace brakes? ive been wondering because mine make a squealing sound a lot of times...
Old Oct 14, 2025 | 06:37 AM
  #50
01ACCORD's Avatar
01ACCORD
Only true way is to have them inspected. Wear indicators will make a scraping sound. Any time you start hearing noises, get them inspected before they ruin the rotors.
Gary
