Odometer stopped working...any ideas?
Old Dec 22, 2004 | 06:50 AM
dlax035's Avatar
dlax035
Default Odometer stopped working...any ideas?
hey a little while ago i noticed my odometer on my 94 accord stopped working..i have yet to take it to a mechanic, but does any one have any ideas? lose connections? broken relays? help me out thanks
Old Dec 22, 2004 | 07:35 AM
bluetwo's Avatar
bluetwo
Relevance is irrelevant
Does you speedometoer still work? If not it could be your VSS, the vehicle speed sensor... ...if you have cruise control a dead VSS would keep the cruise from working as well.
Old Dec 22, 2004 | 07:36 AM
lkailburn's Avatar
lkailburn
college kid
this happened to my friend. speedo works fine. but odometer stops working sporadically. haven't fixed it yet
Old Dec 22, 2004 | 09:04 AM
dlax035's Avatar
dlax035
hey yeah the speedometer and cruise work fine...no problems...just no idea why the odometer would quit
Old Dec 22, 2004 | 09:20 AM
bluetwo's Avatar
bluetwo
Sorry brain fart. Lemme see what I can come up with...
Old Dec 22, 2004 | 10:37 AM
dlax035's Avatar
dlax035
hey thanks..if u find anything lemme know
Old Dec 22, 2004 | 03:43 PM
Honda3002's Avatar
Honda3002
Default Some Idea's to fix the problem
Your odometer is connected to the distrubator by either 2 or 1 wire for it to work. Here is a web site for a manual for your Accord , http://www.hondahookup.com/manuals/ First check for a loose connector's or wires near the distributor. I hope this helps.
Old Dec 22, 2004 | 06:49 PM
dlax035's Avatar
dlax035
hey thanks alot..ill check that out
Old Dec 22, 2004 | 07:11 PM
MBenztech's Avatar
MBenztech
Solid as a Rock!
rpm sensor??
Old Dec 23, 2004 | 05:24 AM
dlax035's Avatar
dlax035
the tachometer still works...if it was the rpm sensor would the tach still work?
