do you have aftermarket gauges installed? i would just pull out the gauges and start from there. those odometers are electric i believe, so just pull the gaues out and check for bad connections/damaged print on the green sheet.
no, it is not that bad. i don't know specifics on yours but its all screws and connectors. i don't think you have speedo cable so its not bad at all. if you had a speedo cable, thats sometimes bad, but i don't think you have one. most cars you just need to remove the bezel(part around the cluster) and then unscrew the cluster.
hey thanks!...
so the bezel is that a part of the dash around the cluster? or the clear shield that protects the gauges as you look at them? thanks so much
