1990 Honda Accord PWR Door Locks Problem
Old Sep 12, 2004 | 07:30 AM
delancj's Avatar
delancj
Default 1990 Honda Accord PWR Door Locks Problem
I have a 90 Accord LX w/ pwr locks. One day I tried to use my pwr locks and nothing happened. They won't lock or unlock electronically. I can hear the relay click inside the pwr lock module but still the lock motors don't move. I have checked fuse #27 and its good. I am getting power to the pwr lock module and the ground is good. Got any other ideas? Is the module bad?
thanks
delancj
Old Sep 17, 2004 | 07:41 AM
wedley2's Avatar
wedley2
bboy Wesley West
same problem with me, when my uncle brought it to the body shop, they broke it and said they wouldnt replace it. but when i unlock, it doesnt go anywhere and locks back, so what i do is force it upwards with one hand on the power lock and one hand on the outside door. it should open the door, this is a temporary solution until u can buy a working power door lock actuator. ihave a 90 ex.
Old Jan 14, 2005 | 11:28 PM
j0sh_o6's Avatar
j0sh_o6
hello,
i had the same problem as you described push button you can hear relays clicking yet no movement if all your doors started this at same time i would say check ebay for a "DOOR LOCK CONTROL" thats the name of it drivers side lil grey box above speaker well was in my 92 atleast
when i took apart the axuators and hooked them up and hit the button it moved about 1/4 of a turn the motor did so i found the contol on ebay and installed and problem solved door locks work great again
if anything i would recomend unhooking the door lock control just unplug the wire harnest when i talked to local dealer to price one of these they said they can go haywire and lock and wont want to allow you to unlock your doors and you have to go through all this trouble and stuff btw priced at deeler was i think $115-$130
Old Jan 28, 2021 | 10:07 AM
Robert Snyder's Avatar
Robert Snyder
thanks
delancj
I'm having the same problem but can't find the answer in this site????????????????????
Old Jan 28, 2021 | 10:10 AM
Robert Snyder
Did you get an answer from anyone? I have the same problem.
Old May 9, 2025 | 09:00 AM
daryelcorran's Avatar
daryelcorran
sorcerer
Accord
4
Apr 17, 2009 06:52 PM
KrazyPRican
Accord
Aug 26, 2006 08:42 AM
fac90
Accord
4
Feb 23, 2005 10:27 AM
motu
Accord
6
Dec 2, 2003 10:45 PM
