HELP! Installing XM radio
Old Apr 11, 2004 | 01:51 PM
shannonk's Avatar
shannonk
Default HELP! Installing XM radio
I'm going to look dumb, but I'm trying to install XM radio using FM modulator... I have everything hooked up but cannot find any of the antenna wires to hook up to (to vehicle audio stereo, AM/FM antenna) and how about the 12v power terminal?
can someone please help!?!?!?!??!
Old Apr 21, 2004 | 11:12 AM
SOHKeg's Avatar
SOHKeg
sounds like you didn't find any connections that you need to make. pull out the stock headunit and unplug the antenna from it. then plug that antenna into the XM box, and the XM aftermarket antenna into the headunit. then you tap a constant (battery) source, accessory (switched power), and your ground. set your preset for whatever the FM modulator is set on, and you're done!
Dimi
4
Feb 15, 2004 01:46 AM
Daniel
News & Rumors Archives
9
Sep 12, 2003 07:46 AM
nd4speedm1
14
May 1, 2003 12:21 AM
yeatsisdead
Accord
17
Mar 20, 2003 10:19 AM
Tirod
15
Jan 16, 2003 09:17 PM
