opinions anyone?
ok here's the deal. i threw a rod bearing in my b16. i have a complete built top end, and a complete stock bottom end. this is why she threw the bearing. now the problem i am faced is what to do with it...should i put in a lightweight crank (where can i find one???) or should i stroke it? what should i do from here? whats the cheapest and best route? where can i go from here.
i know of a ls motor, i can get ahold of its bottom end. only thing is can i do that transplant? b18 crank n stuff to a b16...it would be my cheapest bet if possible.
What do you use the car for?
Stroking an engine takes away some of your rev potential, and a lightweight crank makes city driving more difficult than having a lightened flywheel.
-Harry
AIM: NDcissive
-Harry
AIM: NDcissive
In that case, I'd probably look to change blocks all together if you want some more displacement. A nice B18C block should hold up nicely and let you end up with a poor man's ITR. The B16 just doesn't have the kind of deck height I would be comfortable putting a longer stroke on.
-Harry
AIM: NDcissive
-Harry
AIM: NDcissive
well im kinda in a jam of money. i just dropped 1600 on a full head setup for my b16 and neeed something to go along with it in the bottom end...
is it possible to put my b16 head onto a b20 block? or how bout a b18 block. what can i do with my head?
Yeah, you can put that head on a b20 or b18a/b block, but you're going to need to do the standard modifications that every frankenstein build requires. With the B18C block, it wouldn't be an issue.
-Harry
AIM: NDcissive
-Harry
AIM: NDcissive
what are these standard modifications you speak of? so i can bolt up to a b18 good to go? cause i got a b18 sitting at my shop with a blown head gasket wanting to be loved. only thing abou tthose is that i have heard you will throw a rod bearing...exactly what i did, if you throw a b16 head on it? is there any counter measures i can go with to prevent this? am i looking at an insane machine if i do this too? what would you do?
imagine this situation...fuct off b16 block, a b16 pnp race head with all the goodies, and an ls engine. what would you do? anyone?
Oh, and yes. A properly assembled LS/VTEC is a crazy beast.
You can have the crank knife-edged and balanced, that will lighten both your crank and your wallet.
Stroking the B16 block is a bad idea IMHO. If I had to stroke a Honda motor, it would be a B18A/B with a deck plate setup.
