Rear Disc Conversion
Old Dec 29, 2002 | 07:00 PM
FourthGenHatch's Avatar
FourthGenHatch
I'm RICK JAMES, bitch!
Which is odd since CRX was light so why does it need the beefy brakes over say a Sedan.
Old Dec 29, 2002 | 07:39 PM
WhiteRice's Avatar
WhiteRice
90-91 Si hatch brakes (drum)
90 ex 4-dr (drum)
90-91 CRX Si(disc)
Boy, I really love Majestic Honda!!!!!!!
Old Dec 29, 2002 | 08:17 PM
FourthGenHatch
Told J0o Yos!
Old Dec 29, 2002 | 08:59 PM
malfuncion's Avatar
malfuncion
Z20 H8R
So what youre trying to say is....CRX 90-91 Si only, will bolt on to my 89 hf?
Old Dec 30, 2002 | 03:26 AM
jaje's Avatar
jaje
HC Racer H5
no...i was wrong about what other models had rear discs (the sedan and hb don't have them)...easiest car for you to find is a 90-93 integra (all came with rear discs...which is where i got mine from)...all you need to do is take off the rear lower control arm wtih evyerthing attached (cut the brake hose but also take the rear parking brake cable all the way to the actual lever inside the car (it's just 2 skinny cables)
Old Jan 2, 2003 | 11:05 AM
FourthGenHatch
If you have a CRX you will need CRX 90-91 CRX Si ebrake cables, the Integra and Civic ones are longer. It would be in your best interest to just get everything from an CRX Si.
Old Jan 2, 2003 | 12:05 PM
jaje's Avatar
jaje
HC Racer H5
you can use the teg cables if you get it from one...you just have to route the cable a little differently b/c there it is longer and there will be some extra slack
you can't switch cables b/c they are connected so you are stuck w/ whatever cables are attached to the rears
it would be wise getting exactly from another crx si but they are much rarer than 90-93 tegs which much more abundant
Old Jan 2, 2003 | 12:26 PM
malfuncion's Avatar
malfuncion
Z20 H8R
well everyone around here has a crx si...so it wont be that hard...thanks guys
Old Jan 2, 2003 | 05:27 PM
FourthGenHatch
Yes you can, the cables are attached to the calipers. You are supposed to punch them out I guess but a lot of them are seized. I just drilled out the metal part and put a screw in to hold it for the new calipers...
Old Jan 2, 2003 | 07:02 PM
Knightmare69's Avatar
Knightmare69
Hater
What about for a 91 Civic DX HB? Or is there an AEM Kit for that?
