mpfi swap engine flooding!!! HELP!!!
Old Mar 15, 2007 | 11:02 AM
90_crx_flaze's Avatar
90_crx_flaze
Drift King
heres a question did u change your intake manifold gasket?, i did the swap a long ass time ago when i was 17 and i though i could just use any ole' gasket and i had to change my intake cuz the seal between the 4th cylinder and the coolant was broke which caused coolant to seep into the IM runner and right in to my cylinder
Old Mar 15, 2007 | 12:55 PM
jdmeg6hatchy's Avatar
jdmeg6hatchy
i
Originally Posted by daveb91
Ok so your using the 92 engine but are you using all the OBD0 components with the ecu?
yes.
its a 1992 civic dx engine. we used a crx si ecu and distributor. do we have to swap of the map sensor????
Old Mar 15, 2007 | 01:00 PM
jdmeg6hatchy
i
Originally Posted by theleprechaun
I still stand by with leaking gaskets. At 3000 rpm you would develop a nice draft through any leaks and destroy your air/fuel mixture. Does it die at 3k or just limit there?
It was limiting at 3k, we re set the tming and that fixed the problem!! however the car still wont stay running unless you have your foot on the gas. any ideas?????????? do we need to switch out the dx dpfi map sensor for a si mpfi map sensor????
