Help! Car just died!
I finally got the dizzy cap off...bottom screw stripped and took out the spark plugs...well three plugs...one is siezed and I have to figure out how to get that out too:
http://i134.photobucket.com/albums/q...bum/dizzy1.jpg
http://i134.photobucket.com/albums/q...bum/dizzy2.jpg
http://i134.photobucket.com/albums/q...bum/dizzy3.jpg
http://i134.photobucket.com/albums/q...bum/dizzy4.jpg
http://i134.photobucket.com/albums/q...bum/dizzy5.jpg
http://i134.photobucket.com/albums/q...bum/spark1.jpg
http://i134.photobucket.com/albums/q...bum/spark2.jpg
What now...what am I looking for now that I have the dizzy cap off?
Jason
Jason
Well, your plugs don't look completly horrible, but your dizzy is REAL dirty, i would use some starting fluid and spray the crap out of the inside of your dizzy, and wipe it out. Starting fluid will work good, becasue it disipates and leaves no residue. Also, I would change your cap and rotor asap, it looks to be a little burnt.
Also, when you turn your key on, does your check engine light come on for 2 seconds then shut off? You should asl ohear a whizzing or whinning noise from your back seat, if it isn't whining, then you need a new main relay. You can try and hit your main relay while starting the car, that should get it started, then drive homne and go from there.
double check your gaps on the new spark plugs, use antiseize, and dialetic grease.
take a peak at the distributor shaft and make sure it's not damaged,
a new cap and rotor is a good step to troubleshooting the problem
No SPARK!
So my friend got home from his trip to the US with his truck and hauled my car back to my house and he determined that I have no spark...but now what.
I have changed 3 out of four spark plugs...one is seized...and I'm having trouble with it.
I have also put in a new dizzy cap and rotor.
Now....?
Jason
Now....?
Jason
No spark could mean bad coil or bad ignitor (both are in the distributor).
The coil converts 12V to thousands of volts and the ignitor sends the voltage/energy pulse to the spark plug creating the spark at the correct time.
If not...which one would you recommend I go at first?
Jason
is it a dual point if it is then look at ur ecu under the carpet on the pass side footwell. if it flashes 13 i think the number is then its ur secondary injector which will cause it not to have saprk along with not starting.
