Ready For a Clutch
OK i found the right clutch....89 integra. finding a lightened flywheel however is seeming pretty hard to find. (since my engine (zc) is froma 89 tegra i need a flywheel that fits that(200mm)
I ordered my act streetlight flywheel for my crx from here.
http://www.machonecar.com/Customer.aspx
It was the least expensive place i could find, and i received it within a week. Very good service. I paid 199 for it, shipped.
if you have the CRX transmission, just use flywheel and clutch for the CRX - you don't want to use the Integra flywheel with the CRX L3 transmission anyway since the Integra doesn't use a pilot bearing and you have nothing to support the end of the input shaft - bearing won't last
Originally Posted by Danpjack
does urs have zc?
i'm getting this clutch unless some1 tells me that this is the wrong 1 for me
https://id304.securedata.net/importl...4f6a23085f3ee7
Why not just go to your local auto parts store and get a clutch kit for around 150 bucks, then get the act streetlight flywheel. This is what i did. From what i've read, you don't need those expensive clutches, unless your boosted. That is, if the one you posted is even any good.
