Dude your motor does not have that much TQ... Get a decent clutch for around 150$ and the ATC flywheel... you will have a much better setup than that clutch u are lookin at..
I was always told to never get a clutch the motor could not handle.. IMO, the more HP you have the better your clutch should be....
ok i found out that i need a clutch for mt tranny (L3 Stock) and Flywheel for engine and Crx Clutches are cheep and the integra flywheels are about 230 so not to bad
if you have the CRX transmission, just use flywheel and clutch for the CRX - you don't want to use the Integra flywheel with the CRX L3 transmission anyway since the Integra doesn't use a pilot bearing and you have nothing to support the end of the input shaft - bearing won't last
