Some noob CRX questions.
Old Sep 1, 2005 | 06:23 AM
Temporary's Avatar
Temporary
Isn't it a OBD2 motor?
Old Sep 1, 2005 | 07:52 AM
VTEC-Power's Avatar
VTEC-Power
OBD2 and thats why we said the hasport harness
Old Sep 1, 2005 | 09:03 AM
Temporary's Avatar
Temporary
Wow, i could have sworn the b16a2 from a 99 Si was OBD2.
Ok, if i buy the mounts, and the wire harness, Anything else i need? Also will this work for any B series, like if i wanna sale my b16, and move to a b18??
Exempt's Avatar
Exempt
2 tone Rex
Umm... A 99 would be OBD2A...
But... If you do this swap, its best to change the car to OBD1... OBD2 is a bitch to wire into an earlier OBD car, and then to tune...
Old Sep 1, 2005 | 09:37 AM
ullerw's Avatar
ullerw
rexerk
yeah its def. an obd2, they started obd2 all the way back in like 96? anyway u can convert the engine to obd1 rather than converting the car to obd2
Old Sep 1, 2005 | 09:39 AM
ullerw's Avatar
ullerw
rexerk
oh yeah it will work for any b series, the mounts will anyway and the axles and most of the wiring, unless u go with a b18a/b, which you wouldnt need to wire vtec for and would need a different ecu, personally i would sell the b16 and get a b18, the b16 is way to overhyped and doesnt have any low range torque
Old Sep 1, 2005 | 09:48 AM
Temporary's Avatar
Temporary
So, sell the B16, with that money and the insurance i buy this.....
http://www.hmotorsonline.com/shop/sc...age&item=30011
Add the "Please Note: We now offer the Hasport Hydraulic tranny to cable car conversion kit for $429. Also available is the Hasport High Horsepower upgraded motor mount kit for $300." to the order, and then buy a wiring harness, and i should be ready to go. Anything missing? Sorry if this thread is getting annoying.... but thanks for everyone's help!!!
Old Sep 1, 2005 | 09:51 AM
VTEC-Power's Avatar
VTEC-Power
if it is that expensive sell your motor and get a B16a motor with 0BD0 already
Old Sep 1, 2005 | 09:52 AM
ullerw's Avatar
ullerw
rexerk
you could do that, or you could go with this http://www.hmotorsonline.com/shop/sc...age&item=30009 and make sure you get an obd1 one, it would make the swap much easier and its much cheaper than the type R engine, although if you have the money i guess id say do it on the type r.
Old Sep 2, 2005 | 06:25 AM
Pete's Avatar
Pete
Civilian
I'm sorry, I forgot, it is an OBD2 motor. I too converted to OBD1 before installing it though, that's why I got confused. Heh, and OBD2 motor with and OBD1 setup in an OBD0 car :run:
