clutch installation
Old Feb 23, 2004 | 05:19 PM
JackDaniels's Avatar
JackDaniels
Default clutch installation
i have decided to install the clutch myself...i have a basic idea as to how to install it but i was wondering if neone can show me were i can find a writeup on how to install them on my 91 civic hatch...can anyone help?!?!?
Old Feb 23, 2004 | 06:18 PM
jaje's Avatar
jaje
HC Racer H5
www.helminc.com crx 90-91 service manual (best writeup out there)
Old Feb 29, 2004 | 05:15 PM
JackDaniels
I dont want to buy a book. I need a write-up on how to install it, ASAP! Can anyone help me?
Old Feb 29, 2004 | 07:41 PM
cwhiteboy's Avatar
cwhiteboy
You should get the book. You would be amazed on how much you would use that book. As for a writeup online, i've never seen one. I've seen half ass walkthroughs, but they never cut it.
Old Feb 29, 2004 | 07:52 PM
ZiviCase10287's Avatar
ZiviCase10287
RacinMasonC
Take out both half shafts then,
TRANNY
1. take off everything on tranny
2. unbolt backside tranny mount off the tranny
3. get all tranny bolts out of mounts
4. pull off tranny
CLUTCH
1. take off pressure plate with 10 mm 12 point socket
2. take off flywheel with 17mm 12pt socket
3. resurface flywheel most likely, otherwise skip #2 and #3
4. Instal new throw-out bearing
5. instal flywheel
6 put the clutch disc and pressure plate on the fly and lightly tighten bolts, put the clutch alignment tool in and then tighten down pressure plate bolts
7. install tranny and everything you took out
8. install half-shafts
Old Mar 1, 2004 | 04:46 AM
jaje's Avatar
jaje
HC Racer H5
that book is the best writeup on how to work on your car...it is what the honda service technicians use and train with
Old Mar 1, 2004 | 04:49 AM
jc836's Avatar
jc836
Be sure to support the tranny when you remove the mount. BTW: my dealer says that the project takes up to 8 hours to do and the clearances under there are fairly tight. Some techs actually drop everything out.
GET THE HELM-please! You will not regret it. Has saved us a lot of time doing simple things. The wiring diagrams alone are worth the money.
Old Mar 1, 2004 | 01:59 PM
ZiviCase10287
RacinMasonC
8 hours, dropped and then back in.
Phat8186
Accord
6
Mar 31, 2003 12:08 AM
AwwsChwA
Track & Autocross
2
Feb 24, 2003 05:44 PM
shockwave
Jan 4, 2003 03:12 PM
JackoliciousLeg
Jul 31, 2002 08:28 PM
sir_crx
Engine Swaps, Tech & Tuning
6
Jun 23, 2002 02:31 PM
