Gauge Cluster Question
Old Oct 15, 2003 | 12:07 PM
Magik's Avatar
Magik
Default Gauge Cluster Question
Is it possible to take a gauge cluster from a 90 Civic HB Si and put it in a 90 Civic HB STD?
Some have said that this is not possible as one is electronic and one is mechanical...can someone verify this...debunk it...or is there a way to make it work.
I will have my hands on one soon as I just picked up a used Si for parts for my car (body etc) and I've always wanted the tach in mine.
Jason
Oh...and are the windshields in both car's the same?
Thanks Guys! :canada:
Old Oct 15, 2003 | 03:35 PM
Magik's Avatar
Magik
Anyone?
Old Oct 15, 2003 | 03:57 PM
FourthGenHatch's Avatar
FourthGenHatch
I'm RICK JAMES, bitch!
It will bolt in fine. They are electrical with the exception of the speedo is mechanical and uses a cable to turn it, and that goes for both STD and Si clusters.
Old Oct 15, 2003 | 04:02 PM
Magik's Avatar
Magik
So it is an exact swap? Is that what you're saying?
Plus, what about the windshield? Are they the same as well or do you know?
Jason
Old Oct 15, 2003 | 04:52 PM
oneslowrex's Avatar
oneslowrex
Shouldn't be any problem. 90-91 all used an electronic vss so everything should just plug right in.
Old Oct 15, 2003 | 05:27 PM
FourthGenHatch
I don't believe any 88-91 used an electronic VSS. Except the JDM Si-R.
And yes I am saying it bolts right in.
Old Oct 15, 2003 | 05:52 PM
Magik's Avatar
Magik
Anyone have any idea about the windshield?
Old Oct 15, 2003 | 06:40 PM
FourthGenHatch
Windsheild should be the same for all the Hatches.
Old Oct 15, 2003 | 07:20 PM
Redlinerz's Avatar
Redlinerz
GO TO THE FOURTHGENHATCH.COM site..there is a EXCELLENT how to on how to switch this..
Old Oct 15, 2003 | 09:38 PM
Kai's Avatar
Kai
Rotorphile.
Electro VSS's started in US Civics in '92. Are you sure the SiR had an electronic VSS? I figured it had the same mechanical VSS as the 90-93 Integras. The 89-92 JDM Integras (B16A or SOHC ZC) used a mechanical.
