may have fawked up my pioneer
Old Sep 25, 2003 | 07:22 PM
KeepinOnThaDL's Avatar
KeepinOnThaDL
Default may have fawked up my pioneer
ok, so i jsut got a $300 pioneer head unit the other day and installed it and everything worked great. well I was messing around with my fog light switch and took it off and had the 2 wires from it lose, then stupid me wnated to hear a cd so i put key in then i tucked the wires behind the plastic part near the pedals and under the stearing wheel, then head unit shut off.
please guys i need help! thanks!
Old Sep 25, 2003 | 08:13 PM
toyman99's Avatar
toyman99
Check your fuses in your car (is your clock and domelight working)
Check the RED wire on both sides of the gray little thing. That may have blown.
Old Sep 25, 2003 | 08:20 PM
KeepinOnThaDL
yes, clock and everything else is working. where is the red wire at? the one behind the head unit? and how do i check and see if thats the problem?
edit - is it possible that the head unit got fried? (please god i hope not) and could it be the fuse in the back of it?
Old Sep 26, 2003 | 06:26 AM
toyman99's Avatar
toyman99
The red wire is at the head unit.
It is the accessory wire.
Next to the radio is like a gray small tube thing. There is a resistor inside that blows when you surge/short the radio.Check for power on both sides with a meter (12 volt DC)
Old Sep 26, 2003 | 06:39 AM
95civicEX_h22's Avatar
95civicEX_h22
Slo N Low
Ooohh.
To reset your clock and program all your radio stations seem like a hassle to you? With ANYTHING electrical you SHOULD always disconnect the battery.
If the fuse is blown you're cool. If not, get it tested to be sure. If I were to take a guess, 'tis fried.
Old Sep 27, 2003 | 07:04 PM
Falkon's Avatar
Falkon
still alive
Does your AC and fan still turn on? Does the deck turn on and no sound? Does it turn on at all anymore? Make sure you test it all out.
Old Sep 28, 2003 | 05:36 PM
Hour's Avatar
Hour
I was installing a kenwood a few weeks ago. Was working, cool.. had just tested unit hooked up - it rocked.. so I was remounting it while it was playing and I guess some wires got pushed back there and it shut off. Wouldn't work, yet my stock unit would work. Thought harness was fried. New harness.. still no kenwood.
Bah I said, didn't pay anything on the KW.. so I got a panasonic and was wiring that up and did it the right way.. wired - test - NOTHING! Absolutely dead.. wouldn't turn on at all.
Turned out to be fuse under hood, the 7.5 Shoulda known, my clock wasn't working or anything either. Strange how stock unit worked though.
Hope your problem is the same - cost me 5 cents to get working, and now I can sell the previously thought to be fried kenwood
P'z
