help on amp installation?????
Old Jun 23, 2002 | 10:23 PM
abocic's Avatar
abocic
Default help on amp installation?????
Hi, can anyone tell me the difference between the two connections? I noticed that I could hook up the amp with the RCA (red and white) from the deck to the amp or connection with the speaker wires. Is one connection better then the other? I need to hook up two amps so I wanted to use the speaker wires for the second amp or should i split the RCA?
Old Jun 23, 2002 | 11:08 PM
Bl@ck's Avatar
Bl@ck
Sinner
usually IMO the RCA's are a better connection.
Old Jun 24, 2002 | 07:12 AM
b00gers's Avatar
b00gers
the RCA connections provide better sound.
if you want to hook up two amps with a HU that only has a pair of outputs: check to see if one of the amps have a LINE OUT option. if so you would connect the RCA to that amp, then from that amp, another pair of RCA to the other amp.
Old Jun 24, 2002 | 07:23 AM
acuradriva's Avatar
acuradriva
or just get Y spliters
Old Jun 24, 2002 | 01:50 PM
abocic's Avatar
abocic
thanks for all the reply =)
I check to see if I had a line out on the amps and I dont =( so whats better use Y connections(do I lose any sound?) or use the speaker wires for the second amp? oh and with the second amp I'll be powering 2 subs so is it okay to just use the speaker wire connection?
Old Jun 24, 2002 | 02:12 PM
Fujiwara Takumi's Avatar
Fujiwara Takumi
It's my first day.
one of your amps doesn't have a pass through? i have bought some cheap ass amps in my day, and all had pass through.
if you havent bought your second one yet, get one with pass throughs. I wouldn't use the high-impedance, (normal speaker wire) jacks provided on an amp. stick with the low impedance and some quality RCA cables.
Old Jun 24, 2002 | 03:09 PM
b00gers's Avatar
b00gers
the Y-connectors will be fine.
Old Jun 24, 2002 | 05:56 PM
acuradriva's Avatar
acuradriva
can't you only use the output from the amp to run another lows amp? i think the signal that comes out will either be hi pass or low pass depending what the crossover is set at on the amp. I just buy h/u's with 3 outputs.
Old Jun 24, 2002 | 06:11 PM
b00gers's Avatar
b00gers
im not sure, but i dont think the signals will effect the second amp. i think the HU shoots the signals to the first amp and at the same time into the line out into the second amp. then each amp does its thing with the signal it gets. not sure.
werd on the HU with 3 outputs.
Old Jun 24, 2002 | 08:29 PM
Fujiwara Takumi
It's my first day.
pass through RCAs are just that, the first amp uses the signal and links up the other amp to the original signal...and i think it's un modified.
Whitelude420
Prelude
May 27, 2003 05:20 AM
jm626clint
Accord
Oct 17, 2002 12:49 PM
turbosix
92+ Civic/EL & Del Sol
19
Sep 20, 2002 09:46 PM
AcsRcool
Accord
9
Aug 7, 2002 06:22 PM
bermanb
15
Jul 24, 2002 12:26 AM
