Amp Install - 12V Supply in Hatch Area of Integra?
Old May 13, 2009 | 07:00 AM
b00gers's Avatar
b00gers
Pry under them carefully...then pull up.
Old May 13, 2009 | 11:34 AM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
Originally Posted by racertyprs
Do you run the power cable under the plastic door sill? If so - how do those suckers pop out?
Not exactly.
The plastic sill trim mounts flat against the door frame; you won't have any space to run your power lead.
The carpet is attached to the sill trim; you will need to remove the passenger's seat and lift the passenger-side sill trim out of its mounts to run your power lead safely.
