Amp Install - 12V Supply in Hatch Area of Integra?
I am installing a very low powered amp in the hatch area of a 1995 3 Dr Integra. Is there a suitable "always on" 12V supply in the cargo area?
Is there a known existing firewall grommet on a 1995 Avura Integra? I didn't see one. There is a large grommet that is being used just to right and below the battery. It's oval and has some wires going through it. The wires are covered with black loom. I can't tell if thise are factory wires or not.
Thanks.
I use the grommet on the driver side...it will lead under the dash area and snake right under the foot panels. It is very easy to access from the engine bay and under the dash.
None "jumped" out at me when I had my head under the hood.
I am using a 10 ga wire.
Thanks.
Apathy Kills
I would strongly recommend using the firewall grommet on the passenger side instead.
It's located behind and below the tray where the battery is mounted and goes completely unused on left-hand-drive models.
In my experience, the driver's side firewall pass-through is already stuffed full with the OEM engine and transmission harness.
The one on the driver side is already used up, but I have had 2 4gauge power cables through there before....running a 10g should be cake.
But ya, if you want to be neat and save a few feet of cable, there is one under the battery. I dont know how it looks like running to the inside though.
Apathy Kills
True. I only suggested the driver side one because the passenger side involves taking the battery out
Once you get through the firewall, you've got plenty of places to secure a power lead while keeping away from the ECU harness. Once you run down the passenger-side door sill and under the rear subframe brace, the rest is dead simple.
Do you run the power cable under the plastic door sill? If so - how do those suckers pop out?
