wiring of subs
ok im new to putting a system in my car but i got 2 12" DEI Pro Plus subs in the box and a DEI amp to go with it. now im getting the rockford fostgate amp kit from best buy, i think its the 4 gauge which from what i hear will be pleanty big enough. the only thing is that i have no idea how to connect it all. i searched and couldn't really find anything. so if anyone has a diagram or somewhere to go to see what wires go where, that would be sweet. oh and the amp is about the size of my foot (9 1/2) so it doesn't seem that big but the friend that i bought them off of didn't know how big the amp was but said they hit hard. im prob gonna hook it up to my stock head unit and as soon as possible, im gonna get the pioneer 7400. so if anyone could help with this, it would really help. thanks
ok i j/ went out and looked at it and here is what i got, dont know if this will help or not. 2 12" DEI Pro Plus subs in the box, set of places to put wires on both sides of subs. the amp is a DEI Audio Mobile Power Series model 2101. on one side there are a freq, bass, and gain turn nobs with arrows on them, a little thing to switch from HFP to OFF to CPF. there is also a status light and 2 red and white plugs for the input and output. and on the other side there is a spot for speaker + - , fuse 30A, and a spot for +12, REM, and GND. that is all that i can see. i hope that helps a little. if not, are there any other ways i can find out about it? i went to the DEI site but they've updated everything. all help would be appreciated.
Searched for those model numbers:
Here are the specs for the stuff you got:
Subs:
Ultra long-throw design - 1.5 inches of peak excursion
250-350 watts RMS power handling
Kevlar-impregnated cone and Conex spider
High-damping, medium-wide EPDM rubber surround
Single or dual 4 ohm, 8 layer voice coils
Heavy 1mm aluminum voice coil former
Aerodynamic pole vent and bumped back plate
Custom rubber magnet cover protects motor assembly
Gold-plated terminals with strain relief design to prevent tensile lead breakage
Pro Plus Subwoofer SpecsPro+ Model Size Magnet Power Handling Impedance/#v.coils
2124 12" 42 oz 300 watts RMS/250 peak single 4 ohm v.c.
2128 12" 42 oz 300 watts RMS/250 peak dual 4 ohm v.c.
Pro+ Model Freq. Resp. Efficiency fs/Hz Re Qts Vas/liter/ft3 Xmax Depth
2124 25Hz - 2500Hz 89 dB 1W/1M 22 3.7 0.35 160.0/5.7 17 mm 5 5/8"
2128 25Hz - 2500Hz 88 dB 1W/1M 30 7.0 0.52 95.8/3.4 17 mm 5 5/8"
Amp:
Mobile Power Series Amplifiers. DEI Model, Description, Price. 2101,
100 Watt Mono Amp w/Crossover and Bass EQ
Will help you out in a little I gotta run somewhere...
Subs:
Amp:
1. go to pawn shop
2. sell gear for as much as you can squeeze out of the guy.
3. go to a stereo shop
4. buy quality equipment
5. smile because now you'll have good sound in your car.
6. sleep better at night
Pretty easy....
Pretty easy....
thanks for the help nando, now does that mean that i got a good system or what? that amp doesn't sound too big, should i get another one or what? i just wish i new what all those numbers meant.haha but hopefully you can help me out some more
edit: so is my amp 4 ohm? i dont really understand all that. and that its 100 watts so is that total? or how is that distributed??
Well like you described above about your subs: "set of places to put wires on both sides of subs." If this is true then you probably have the DVC(dual voice coil) which means its model number 2128. These subs say they handle 300/250 each and with your amp only being 100 watts I can already tell you that your amp is too small and wont push those subs.
See if you can get a response from someone else here because I dont know much about DEI audio so I dont know if they are any good or not.
