Connecting the antena wire from the amp to the ignition switch ok?
A little chin music
From: Cleveland, Ohio - Rock 'n Roll capitol of the World
Originally posted by Toxis
exactly my point. You hook it up to that these days, it will only turn on the amp when the radio is on tuner. Guess you're a huge fan of FM.
My connection which says Antenna on it when I got this amp in 97 Jensen is just a remote turn off/on. Alot of radios have the power antenna connection for a power antenna which turns on the moment the radio turns on and the same when off. Not all power antennas shut off when you go into cd/tape mode. Im sure the majority of power antennas still stay up and have power when even in cd/tape mode cause if they didn't then that stick would just go up and down every time you switch modes.
A little chin music
