Connecting the antena wire from the amp to the ignition switch ok?
Old 01-06-2003, 05:25 PM
DarkInfluence
Banned
DarkInfluence's Avatar
Default Connecting the antena wire from the amp to the ignition switch ok?
I was wanting to know if by doing this would it harm anything cause the Ex Civic has no power antenna and im still using the stock radio. Also what wire behind the dash is the ignition wire that I must find to connect to and if there is a simular wire for the same task then please tell me thanks.
Old 01-08-2003, 05:10 PM
fastball
A little chin music
fastball's Avatar
Location: Cleveland, Ohio - Rock 'n Roll capitol of the World
You can do that with no problem. You can actually tap into the acc line to the stock head unit. That would be the easiest place to go. Otherwise you need a color and wiring diagram to find the ignition acc line under the steering column, which I don't know off hand.
Old 01-08-2003, 08:44 PM
DarkInfluence
Banned
for a 98 ex civic its the yellow with red stripe wire that is the ignition wire.
Old 01-09-2003, 11:48 AM
Toxis
Car Audio Manb*tch
Toxis's Avatar
amps have antenna wires?????? What kind of ghetto amp are you wiring?
Old 01-09-2003, 01:47 PM
fastball
A little chin music
fastball's Avatar
I think he means the remote turn on (half amp blue line trigger). If not then that must be a freaky amp.
Old 01-09-2003, 02:27 PM
DarkInfluence
Banned
It says antenna but its actually the remote wire.
Old 01-10-2003, 04:17 PM
it's an installer trick. if you can't find the remote wire on a stock hu, you use the power antenna out to the amp. it works the same.
Old 01-11-2003, 02:46 PM
Toxis
Car Audio Manb*tch
Toxis's Avatar
I would love to find out who told you THIS little trick. Do you realize that when you do that, the antenna has to be up for the amp to turn on? So if the radio is on tuner, it works, but won't for CD/CD Changer. Go try again rookie...now THAT'S an installer trick, DON"T DO IT THIS WAY!!!
Old 01-11-2003, 03:01 PM
fastball
A little chin music
fastball's Avatar
O.K., I think some of you are getting confused..... let's straighten this out. Some aftermarket radios have two blue line remote outputs: antenna, which triggers only when tuner is selected, and amplifier, which is on whenever the headunit is turned on to any function. Most aftermarket and factory head units have only one output, and I think DarkInfluence was refering to this. Some people refer to it as an antenna output, because in the old days, before power amps in cars were popular (not trying to date myself) the only remote trigger a radio would have would be the power antenna.
Old 01-11-2003, 03:08 PM
Toxis
Car Audio Manb*tch
Toxis's Avatar
exactly my point. You hook it up to that these days, it will only turn on the amp when the radio is on tuner. Guess you're a huge fan of FM.
