No power to the amp!!!
Originally posted by LjN_728
u kno a easier way to see if the power is going thru is checking the red led located on the amp. :thumbup: cuz if no power's going thru, it aint gonna be on.
jordan88- the light isn't on. would the light still be on if my amp blew or my remote lead is no connected?
if u blew the amp or the remote lead wasn't connected, the light would not be on, that light just shows that the power circuit is complete, power is getting to the amp.
if the fuses are fine, and you know that the amp is actually getting power. see if the remote turn on is the problem. get a short piece of wire, long enough to go from the power source of the amp to the remote turn on...connect the two. if the amp doesnt turn on...well you guessed it. if the amp does turn on, you know what to check next.
Originally posted by jordan88
but how can a ground lead affect the power source, i just dun get it, if there is power, the amp should power up without the ground connected properly, rite?
thx
thx
