problem with subd
Old Aug 3, 2008 | 05:04 PM
JLO's Avatar
JLO
7M-GTE!!!! "U-BLOC BITCH"
Default problem with subd
hey the problem I have is the sub hits but the speakers do not work what could the problem be? I checked the ground and it seemed ok????
Old Aug 3, 2008 | 05:57 PM
freeze101's Avatar
freeze101
Any chance you could supply a bit more info please like what system you have head unit and such like have you checked all cables visibly and with meter or other device ?
thanks
freeze
Old Aug 3, 2008 | 09:23 PM
JLO's Avatar
JLO
well im not too good with sound systems hence the question. there is a panisonic deck, 12 inch kicker with 2 kicker amps. i just bought the car (98 civic ex U.S.) and the guy said it the speakers were cutting out but it was fixed, while I wait for this guy to get back to me does anyone know what the problem is ?
Old Aug 4, 2008 | 06:21 AM
freeze101's Avatar
freeze101
I would start the process of elimination ,for instance ,try the speaker with somethin else do they work? does a different speaker work with this HU? because really it could be a number of things ,like wiring fault ,faulty HU or Speakers? broke wire somewhere ?
sorry I cant help much more than this
freeze
Old Aug 4, 2008 | 08:09 AM
M@rshy's Avatar
M@rshy
٩(̾●̮̮̃̾•̃̾)۶
Like Freeze said. It could be a bad HU(Head Unit), loose or broken wire, bad speakers, etc. I would check the voltage of the wires at the speakers.
Since none of your speakers are working I'm doubting its the speakers. It could be the HU, but more likely the wires were just pulled from the harness or came loose.
Old Aug 4, 2008 | 09:58 AM
JLO's Avatar
JLO
great thanks guys Ill give it a shot
Old Aug 4, 2008 | 03:01 PM
Travis@DICE's Avatar
Travis@DICE
Banned
So all you are getting is bass you are not getting any mids and highs from what I am understanding.
Are you running an amp for your mids and highs as well?
Old Aug 9, 2008 | 03:28 PM
Tedmond's Avatar
Tedmond
if you got a volt meter, you can check if your amps are working. dissconnect your speaker leads, set dmm (digital multi meter) to 20v dc. connect black to neg and red to pos. play some music. the meter should show some voltage when the unit is off, it will go to 0 - 2v
