How to hook a separate battery up? Also the pros and cons
My question is, how do i exactly hook on a separate battery in the trunk for my amps? I have a clue but I want to make sure. Also any pro and cons to that? thanks!
Originally posted by igo4bmx
why would you wanna waste money on another battery?
upgrade your alternator for more amps for your system
yea i kno wut you mean and i was thinking about that. how much for a higher amp output alternator? I guess the whole car warranty comes in mind. but i'm open to suggestions
generally most of their alternators are putting out about 135 amps
Originally posted by 94uhkord
A good reason to have a separate battery for your system is if you are running a high power/high current system and would rather have a dedicated power source for your system so you aren't pulling power from the electrical system for the rest of the car. Another battery by itself would't be wise, best to do battery, hi output alternator and stiffening cap.
Pros of an additional battery:
Extended listening possible with the car off
Cons of an additional battery:
Additional strain on factory charging system
Additional weight
Additional installation space/safety requirements (you have to vent it)
Need an isolator
Personally, I think that the cons outweigh the pros.
You should really take a look at what your total current draw is, then evaluate your electrical system need....post what you are trying to run.....
This post has some good info about the pros/cons of both additional batteries and the effect of a H.O. alternator:
https://www.honda-acura.net/forums/s...threadid=29940
h:
