Vehicle Wiring Diagrams Database.
Old Feb 15, 2008 | 01:23 PM
  #31
bobbycswa's Avatar
bobbycswa
Default 2005 pilot
Do You Have A Wiring Diagram/ Schematic For A 2005 Pilot Ex
Old Feb 16, 2008 | 09:48 AM
  #32
Tedmond's Avatar
Tedmond
yeap check uptop. make sure you get a bypass module for the transponder bypass and also, tkae your time and test your wires.
Old Mar 4, 2008 | 06:46 PM
  #33
bobleblond's Avatar
bobleblond
do you have the wiring diagram for an acura rsx 2003 premium it's the one without the bose system
Old Mar 5, 2008 | 03:55 AM
  #34
Tedmond's Avatar
Tedmond
for sure bud, if you need instructions how to remove the radio if you plan to upgrade feel free to ask. may i ask wheat you are planning to do? audio or security/remote starts?
Old Mar 5, 2008 | 08:06 AM
  #35
PepittoK20's Avatar
PepittoK20
For the wiring diagram for the acura rsx 2003 premium,we want to replace for another deck,but we need the code of the color,where can I find that please.
Old Mar 5, 2008 | 08:55 AM
  #36
Tedmond's Avatar
Tedmond
its at the top of the page, look for RSX and it will be there. Radio pin out and wire colours all labeled. I suggest you spend 12bucks and get a radio harness. if you live in canada like i do, head to a canadian tire and grab their wiring harnesses they are $9.99. this will save you the hassle of cutting wires and making mistakes.
Old Apr 5, 2008 | 07:58 AM
  #37
fIxMYcaR's Avatar
fIxMYcaR
if you could i need the 1990 honda accord ex wiring diagram for auto stereo system. thax
Old Apr 5, 2008 | 12:59 PM
  #38
Tedmond's Avatar
Tedmond
look at any of the accords under 1998, the wiring pinout is all the same.
Old May 18, 2008 | 05:50 PM
  #39
bass2low1's Avatar
bass2low1
Default bose amplifier/2004 acura mdx
i located the bose amp for the sub and center channel but i wold like to install line output converters to catch a clean signal after the fac. amp. i am installing a 4 ch. amp for the hi and a amp for a prefab box... any help would be greatly appr.
Old Jun 25, 2008 | 10:31 AM
  #40
kathyyem's Avatar
kathyyem
Originally Posted by Tedmond
hey, here you go. from now on, i will post both audiovox and scytek diagrams as one so those that are unsure can cross referance their wires and make sure which is correct. http://www.4shared.com/file/31819435...rd_4_Door.html
just a note to you h23sirlude, the door trigger wire is:
BLACK/WHITE (-) located @ DRIVERS KICK PANEL. usually it will be easily seen, if not, it will be in a gray plug, high up in the dash area. Always test with a DMM (digital volt meter) do not use test lights !!
I need the wiring diagram for a 1992 honda accord Lx for the alarm and keyless entry....thank
