how to wire amp
Old Oct 2, 2006 | 10:04 AM
95-civic-hatch's Avatar
95-civic-hatch
oh yeah are you a soldier too.
Old Oct 2, 2006 | 04:38 PM
Omie's Avatar
Omie
ew n!gg@ u g@y
wat kinda box is it or are you building the box yourself
Old Oct 2, 2006 | 06:15 PM
b00gers's Avatar
b00gers
Originally Posted by 95-civic-hatch
thanks for the detailed pic boog haha. the way i have it is the subs wired normal and the pos from both running into the pos terminal and the same with the neg. i guess it has the same results at the end?? i use to be really big into car audio when i was younger and have really lost my touch. this sucks
Same thing :hs:
Old Oct 4, 2006 | 10:48 PM
SUPER LAUBO's Avatar
SUPER LAUBO
KiMBO's Hubby
Originally Posted by b00gers
:lmao: that's a freaking awesome drawing.. but i concur with mr. boogers.
you can potentially burn up your amp. you have to find out the resistance of those subs. if they are 4 ohm, your amp will be seeing 1ohm, which will most likely overheat.
when you parallel your subs (the method boogers told you) the resistance is cut in half. when you bridge your amp the amp will see half the resistance, hence 1 ohm for 4 ohm subs.
for that setup to work without the potential for your amp to burn up, you need 8 ohm subs or have one sub for each channel.
Old Oct 4, 2006 | 11:07 PM
b00gers's Avatar
b00gers
Are you sure when you bridge the amp, the impedance is cut AGAIN?
Given that diagram and those subs being 8ohm SVC....the amp would be seeing a 4ohm load.
If those subs in the diagram were 4ohm, then the amp would be seeing a 2ohm.
Correct me if I am wrong.
Old Oct 4, 2006 | 11:46 PM
dleccord's Avatar
dleccord
where did you get 1ohm from?
that's correct
Old Oct 6, 2006 | 10:17 AM
95-civic-hatch
they are 8 ohm subs....so am i good????
Old Oct 6, 2006 | 11:01 AM
97teg's Avatar
97teg
I think he may have meant that each channel will see half the load when its bridged. This is why 2 channel amps that are stable down to 2 ohms stereo are only stable to 4 ohms bridged. That is my guess anyways.
Yes you are fine. Just make sure you have it hooked to the right terminals on the amp. It should be labeled bridged and show you where the wires will go.
Old Oct 7, 2006 | 12:32 AM
dleccord's Avatar
dleccord
but those subs are svc 8ohms. 2ohms are out of the question.
Old Oct 7, 2006 | 10:30 AM
97teg's Avatar
97teg
I know. Each channel "sees" half the load. On a four ohm bridged load each channel will act like it has a 2 ohm load for a 4 ohm total load (2 ohms on one channel + 2 ohms on the other = 4 ohms total). But anyways thats not very important. Not something i would really worry about. In the end as long as the final load is the same as what the amp is rated for in that mode (bridged, stereo whatever) or higher it will be fine.
Again yes the way B00gers illustrated is perfect for that amp.
