ssss sound from tweeters
Originally posted by steveng
my infinity tweeters are making this sssss noise when i play loud. does this mean they are cheap quality or there's something else that caused this? anyone?
also some tweeters like quarts are a little bright for tweeters. i don't know about yours, but you might consider attenuating the tweeters if there is an adjustment on the crossovers for it. try setting them down about -3 or -6 db if your crossovers have that adjustment.
my guess is they are probably a little bright anyway based on what you said.
sometimes the hiss sound is very noticable that i forgot i was listening a CD
the crossover is supposed to be adjustable which is not clearly explained on the infinity manual. but for gain control, should i set it higher or lower?
Originally posted by Bass Mechanic
if the crossover is adjustable there is either a switch. knob with 2-3 settings, or a jumper on the board with 2-3 positions. usually the positions are labled 0, -3, -6 i am assuming your using the 0 db setting. try going to the -3 or -6 personally i have found that if there is a - 6 setting the tweets are usually way too loud on the 0 setting.
inside the xover box, but when i opened it up, everything was sealed. and there was no lable of db's. but anyway, what is jumper?
on inifinity manual, they called it contour control and mentioned something about moving jumper from left pin to right pin
the jumper can be as small as a pencil eraser or smaller. if there is one you will need tweezers or a small pliers to remove it.
Originally posted by SumAccordGuy94
just turn down the treble a "notch" or 2... it'll clear right up and save the hassle of fukin with the crossovers...
